Clash Gateway - Transparent Proxy Guide
This tutorial is for users in areas with severe internet censorship. It’s simpler than 在中国,畅快使用Qubes OS,不优雅,但简单(Qubes OS in China bypass GFW, not elegant, but simple!). I tried to implement it using Singbox, but encountered many difficulties (GitHub - iasds/qubes-singroute-gateway: Qubes OS 网络架构实践 — 透明代理、流量转发、策略路由学习项目 · GitHub), so I used the current configuration. Thanks to Hermes agent for helping me complete this project.
Intro
This guide explains how to set up a transparent proxy gateway on Qubes OS using qubes-clash-gateway, powered by mihomo (formerly Clash Meta).
Unlike per-AppVM proxy configurations, this approach turns a single NetVM into a proxy gateway. All downstream AppVMs get proxied automatically with zero configuration — just set the NetVM and go.
What it does:
  • Transparent proxy for all TCP/UDP traffic
  • DNS fake-ip to prevent DNS pollution
  • GeoIP rule-based routing (CN direct, foreign proxy)
  • Subscription parser supporting Clash YAML, vmess/vless/ss/ssr/trojan/hy2/tuic/wireguard
  • Terminal controller clashctl + Web UI for management
How it works:
AppVM → vif* interface → nftables redirect → mihomo
                                           ├→ DNS :53 → :1053 (fake-ip)
                                           ├→ TCP  → :7892 (redir-port)
                                           └→ UDP  → :7893 (tproxy-port)
mihomo routing:
  ├→ CN domains/IPs → direct
  └→ Foreign → proxy nodes → internet
Prerequisites
  • Qubes OS 4.2+
  • A proxy subscription (Clash format, or vmess/vless/ss/trojan/hy2/tuic URI)
  • Basic familiarity with terminal commands
Setup
NetVM Creation
Create a dedicated NetVM to serve as the proxy gateway:
  1. In Qubes Manager, create a new qube:
    • Name: sys-proxy (or whatever you prefer)
    • Type: Standalone (recommended) or AppVM based on Fedora/Debian template
    • Networking: sys-firewall (or your upstream NetVM)
    • Check: “Provides network to other qubes” ← Important
  2. In qube settings:
    • Memory: 512 MB minimum (800 MB recommended for Web UI)
    • Services: Add qubes-firewall
  3. Start the qube and open a terminal
Installation
SSH into the NetVM (or use Qubes terminal):
# Clone the project
git clone https://github.com/iasds/qubes-clash-gateway.git
cd qubes-clash-gateway
# One-click install
sudo bash setup.sh
The installer will:
  • Install mihomo binary
  • Create systemd service
  • Configure nftables for transparent proxy
  • Set up auto-reload for new VM connections
  • Install clashctl command
After installation, clashctl is ready to use.
Subscription Configuration
Add your proxy subscription:
# Add subscription URL
clashctl /sub add <your-subscription-url>
# Update subscription to fetch nodes
clashctl /sub update
# Select rule-based routing (recommended)
clashctl /mode rule
Assign AppVMs
In dom0, set any AppVM to use the proxy gateway:
# Check current NetVM
qvm-prefs <appvm-name> netvm
# Set to proxy gateway
qvm-prefs <appvm-name> netvm sys-proxy
That’s it. The AppVM now routes all traffic through the proxy — no configuration needed inside the AppVM.
Usage
Terminal Commands
clashctl /status              # Show status, traffic, node count
clashctl /mode rule           # Rule-based routing (CN direct, foreign proxy)
clashctl /mode global         # Global proxy (all traffic through proxy)
clashctl /mode direct         # Direct connection (bypass proxy)
clashctl /sub add <url>       # Add subscription
clashctl /sub update          # Update all subscriptions
clashctl /sub list            # List subscriptions
clashctl /node                # List all nodes
clashctl /node <name>         # Select specific node
clashctl /test                # Speed test all nodes
clashctl /test <name>         # Speed test single node
clashctl /dns fake-ip         # Switch DNS mode (fake-ip recommended)
clashctl /restart             # Restart mihomo
clashctl /web                 # Start Web UI (default port 9091)
Aliases: /s=/status, /m=/mode, /n=/node, /t=/test
Web UI
clashctl /web                 # Start with auto-generated token
clashctl /web --secret <pass> # Start with custom token
Open http://<netvm-ip>:9091 in any AppVM browser, enter the token.
The Web UI provides:
  • Dashboard with traffic stats and exit IP
  • Node list with per-group speed testing
  • Connection viewer with exit node resolution
  • Subscription management
  • DNS cache flush
Verify Connectivity
# On the AppVM
curl -s https://api.ipify.org          # Should show proxy server IP
curl -s https://www.baidu.com          # CN sites should work (direct)
curl -s https://www.google.com         # Foreign sites should work (proxy)
Architecture
│                     AppVM (zero config)                 │
│   Browser, Telegram, etc. → default gateway = sys-proxy │
                      │ vif* interface
│  sys-proxy (NetVM)                                      │
│  │ nftables (qcg_proxy table)                        │  │
│  │   DNS :53    → redirect to :1053                  │  │
│  │   TCP *:port → redirect to :7892 (redir-port)    │  │
│  │   UDP *:port → redirect to :7893 (tproxy-port)   │  │
│  │ mihomo                                            │  │
│  │   DNS server (fake-ip mode, :1053)                │  │
│  │   Redir server (TCP transparent proxy, :7892)     │  │
│  │   Tproxy server (UDP transparent proxy, :7893)    │  │
│  │   Routing rules:                                  │  │
│  │     CN domains/IPs → direct                       │  │
│  │     Foreign → proxy nodes → internet              │  │
Persistence
Qubes AppVMs lose /etc/ on reboot. These paths persist on /rw/config/:
Path Content
/rw/config/clash/config.yaml mihomo configuration
/rw/config/clash/clashctl-preferences.json clashctl preferences
/rw/config/clash/clashctl-subscriptions.json Subscription URLs
/rw/config/clash/nftables-proxy.sh nftables rules (auto-loaded)
/rw/config/qubes-firewall-user-script Auto-reload on VM connect
/rw/config/rc.local Boot-time startup script
Multiple NetVMs
You can run multiple proxy gateways for different purposes:
# Create separate NetVMs
sys-proxy-cn    # China-optimized nodes
sys-proxy-us    # US nodes
sys-proxy-uk    # UK nodes
# Assign AppVMs to different gateways
qvm-prefs work-appvm netvm sys-proxy-us
qvm-prefs personal-appvm netvm sys-proxy-cn
Each NetVM has independent subscriptions, nodes, and routing rules.
Troubleshooting
AppVM can’t connect
  1. Check if mihomo is running:
    ssh user@sys-proxy "systemctl status mihomo"
  2. Check nftables rules:
    ssh user@sys-proxy "sudo nft list set inet qcg_proxy vif_interfaces"
    Should list all connected VM interfaces (e.g., vif8.0, vif11.0).
  3. If a new VM can’t connect, reload nftables:
    ssh user@sys-proxy "sudo /rw/config/clash/nftables-proxy.sh"
DNS not resolving
  1. Check DNS mode:
    clashctl /status
    Should show fake-ip mode.
  2. Flush DNS cache:
    clashctl /dns flush
Slow speed / high latency
  1. Speed test nodes:
    clashctl /test
  2. Switch to a faster node:
    clashctl /node <faster-node-name>
  3. Check exit IP:
Web UI not accessible
  1. Check if Web UI is running:
    clashctl /web
  2. The token is printed when starting. If lost, restart:
    clashctl /web --secret <your-password>
Advanced: Killswitch
To block non-proxy traffic (prevent leaks if mihomo fails):
# Add to /rw/config/qubes-firewall-user-script
nft add rule ip qubes forward iifname "vif*" oifname != "vif*" drop
:warning: Warning: This blocks all direct traffic. If mihomo is down, AppVMs lose connectivity entirely.
Advanced: Custom Rules
Add custom routing rules in /rw/config/clash/config.yaml:
rules:
  # Direct CN traffic
  - DOMAIN-SUFFIX,baidu.com,DIRECT
  - DOMAIN-SUFFIX,qq.com,DIRECT
  - GEOIP,CN,DIRECT
  # Proxy specific sites
  - DOMAIN-SUFFIX,google.com,auto
  - DOMAIN-SUFFIX,youtube.com,auto
  - DOMAIN-SUFFIX,twitter.com,auto
  # Fallback
  - MATCH,auto
After editing, restart mihomo:
clashctl /restart
Links
This guide is maintained by the qubes-clash-gateway community. For questions or contributions, open an issue on GitHub.
Actually, Fedora has clash-meta in their repo. Using software shipped by distro should be more favorable than downloading binary by script, since package manager will take care of upgrading.
Good suggestion. This guide uses the debian-13-xfce template.
Kill switch function has been added
Project update (June 2026):
Did a full code quality pass and real-hardware testing on the project. Here’s what changed:
Code quality:
  • Shared error handling library (lib.sh) across all shell scripts
  • Python type hints on all 8 modules, mypy clean
  • 100 unit tests passing
  • nftables atomic rule loading (no half-loaded state)
  • Uninstall verification with --verify flag
  • 4 docs added: architecture, nftables rules detail, CLI API, contributing guide
Real-hardware testing (sys-testproxy NetVM + testapp AppVM):
Found and fixed 3 bugs:
  1. TUN auto-route loop — mihomo’s auto-route: true hijacked its own outbound traffic to proxy servers. Set to false.
  2. DNS unreachable — default DNS 223.5.5.5 not reachable from Qubes VMs. Changed to 10.139.1.1 (Qubes DNS).
  3. Proxy DNS self-loop — proxy server hostnames resolved through mihomo’s own DNS, causing timeout. Replaced hostnames with IPs in config.
Test results (all pass):
  • DNS fake-ip: all domains → 198.18.x.x
  • Proxy exit IP: confirmed through proxy (Singapore/HK nodes)
  • ICMP blocking: 100% packet loss
  • Kill Switch: mihomo stopped → all traffic (DNS/HTTP/ICMP/TCP) blocked, zero leak
New feature:
  • udev rule auto-adds new vif interfaces to nftables set when VMs connect after boot. No manual reload needed.
Did you try this guide yourself? I guess not … The installer in the GitHub repo setup.sh has two bugs that breaks installation: lib.sh is included but not copied, which makes the installation process fail in step 5. Also, the installer downloads mihomo version V3 by default, which is compatible only with very few processors. Most Qubes users will need to install V2. I didn’t go any further… If the simplest thing (the installer) does not work, I do not have much faith in this project, but thank you for your time I guess …
Note to forum moderators: Please moderate the community guides section. Have someone from the Qubes team to test each community guide and mark the guide as safe before allowing posting. Thank you!
It is called “community guides”, precisely to tell the users that it has nothing to do with the Qubes team. In the official documentation, we refer to them as “external documentation”.
The moderation team mostly keeps things in line with the Qubes’ code of conduct and on-topic. The whole quality of the community guides depends on… the community, and your review is exactly what those guides need: feedback.
Note that even the official/core documentation is a community effort but this one is carefully reviewed by the team. This is already a time-consuming task for such a small team.
I apologize; I was still trying to come up with a better approach, so I abandoned this guide quite some time ago. I am very sorry about that.
