Changing template for sys-net
Hello,
I have a bit of a paradox I am trying to solve.
I am trying to switch the template for sys-net from an outdated fedora release to the most recent. The problem is that I need to shutdown sys-net to do so and at the same time lose use of my keyboard.
How do I change this template in this case?? I also need to switch default-dvm but suspect the answer will be the same for both.
Much thanks
There’s a right-click option to change the template in the Qube Manager, unless you’ll also lose trackpad and mouse access.
That is part of the issue. If I do it through DOM0, I lose use of the keyboard, if I do it on Qube Manager, I lose use of the mouse. Is there a script perhaps that can be run to have it make the switch without required my input?
Replace sys-usb by sys-net in the following script:
Duplicate qube, update duplicate, change to updated duplucate, if works fine then delete old one
