Hello everyone,
Currently trying to use the 'pass-io- function to install a Salt repository on dom0.
I can’t use the pass-io function, as it seems it want to use python3.12, when instaled version is python3.11.6, can’t download 3.12 on dom0, but can on my other vm’s templates.
here is the error message:
$ sudo qvm-run --pass-io personal 'cat /home/user/QubesIncoming/sys-usb/Salt.zip' /home/user/Documents
File "/usr/bin/qubes-vmexec", line 5, in <module>
sys.exit(main())
File "/usr/lib/python3.12/site-packages/qubesagent/vmexec.py", line 55, in main
os.execvp(command[0], command)
File "<frozen os>", line 580, in execvp
File "<frozen os>", line 603, in _execvpe
FileNotFoundError: [Errno 2] No such file or directory
tested with a text file just in case and doesn’t works too:
$ sudo qvm-run --pass-io personal 'cat /home/user/Documents/test.txt' /home/user/Documents
