While trying to start sys-usb I have this message
Cannot connect to qrerxec agent for 60 seconds , see /var/log/xen/console/guest-sys-usb.log for detaills
And did you check the log?
Ipouts :
Sudo nano /var/log/xen/console/guest/sys-usb.log
Nothing it is empty in Ouputs:
The log inside the VM is empty, because the VM did not start. How about journalctl -f in dom0?
It is working now … But I have this issue a lot of time after starting qubes
