Can't read usb drives through sys-usb after upgrading to 4.3.1
Hello dear QubesOS team.
After upgrading my QubesOS on the ThinkPad x230 from 4.2.3 to 4.3.1 through a fresh installation I can’t read any usb drives no more. I tried to reinstall the whole system after recognizing the bug. But unfortunately this didn’t change a thing.
After the installation, I rebooted an removed all USB connectors prior the post installation scripts.
The system shows the following bug:
[sys-usb] Error
Failed to mount “removable”.
mount: /mnt/removable: fsconfig() failed: /dev/xvdi: Can’t lookup blockdev.
dmesg(1) may have more information after failed mount system call.
I would be very pleased if you could help me out with this issue, I had no problems with running the OS in previous versions.
Best regards
CBF
Please write in detailed steps everything you did, what you clicked, what you run, its output.
Also open a terminal in sys-usb and run: sudo dmesg and find messages from around that time.
  1. Fresh reinstall through usb drive of the version 4.3.1
  2. Update of the fedora-43-xfce template
  3. Plugged in usb drive to restore my backup
  4. Tried to open the usb drive (labelled removable) in sys-usb which give me the bug in my previous post
  5. dmesg into a log file which I will append on this here
    [ 0.000000] Linux version 6.18.31-1.qubes.fc41.x86_64 (mockbuild@880a5b6cb6b346daa223acf883fe6e0a) (gcc (GCC) 14.3.1 20251022 (Red Hat 14.3.1-4), GNU ld version 2.43.1-14.fc41) #1 SMP PREEMPT_DYNAMIC Mon May 18 22:46:34 UTC 2026
    [ 0.000000] Command line: systemd.machine_id=851fbd4ae36145c3a5cdbf2da175702b root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_privcmd.unrestricted xen_scrub_pages=0 selinux=1 security=selinux
    [ 0.000000] BIOS-provided physical RAM map:
    [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
    [ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
    [ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
    [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000011bedfff] usable
    [ 0.000000] BIOS-e820: [mem 0x0000000011bee000-0x0000000011bfffff] reserved
    [ 0.000000] BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00afff] ACPI NVS
    [ 0.000000] BIOS-e820: [mem 0x00000000fc00b000-0x00000000ffffffff] reserved
    [ 0.000000] NX (Execute Disable) protection: active
    [ 0.000000] APIC: Static calls initialized
    [ 0.000000] SMBIOS 2.4 present.
    [ 0.000000] DMI: Xen HVM domU, BIOS 4.19.4 06/09/2026
    [ 0.000000] DMI: Memory slots populated: 1/1
    [ 0.000000] Hypervisor detected: Xen HVM
    [ 0.000000] Xen version 4.19.
    [ 0.000000] platform_pci_unplug: Netfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated NICs.
    [ 0.000000] platform_pci_unplug: Blkfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated disks.
    You might have to change the root device
    from /dev/hd[a-d] to /dev/xvd[a-d]
    in your root= kernel command line option
    [ 0.000012] HVMOP_pagetable_dying not supported
    [ 0.001682] tsc: Fast TSC calibration failed
    [ 0.001686] tsc: Detected 2594.108 MHz processor
    [ 0.002766] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
    [ 0.002771] e820: remove [mem 0x000a0000-0x000fffff] usable
    [ 0.002778] last_pfn = 0x11bee max_arch_pfn = 0x400000000
    [ 0.002837] MTRR map: 4 entries (3 fixed + 1 variable; max 19), built from 8 variable MTRRs
    [ 0.002842] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
    [ 0.012198] found SMP MP-table at [mem 0x000f5a60-0x000f5a6f]
    [ 0.012498] RAMDISK: [mem 0x114be000-0x11bdffff]
    [ 0.012510] ACPI: Early table checksum verification disabled
    [ 0.012521] ACPI: RSDP 0x00000000000F59B0 000024 (v02 Xen )
    [ 0.012532] ACPI: XSDT 0x00000000FC00A650 000054 (v01 Xen HVM 00000000 HVML 00000000)
    [ 0.012539] ACPI: FACP 0x00000000FC00A370 0000F4 (v04 Xen HVM 00000000 HVML 00000000)
    [ 0.012545] ACPI: DSDT 0x00000000FC001040 0092A3 (v02 Xen HVM 00000000 INTL 20240322)
    [ 0.012549] ACPI: FACS 0x00000000FC001000 000040
    [ 0.012552] ACPI: FACS 0x00000000FC001000 000040
    [ 0.012555] ACPI: APIC 0x00000000FC00A470 000070 (v02 Xen HVM 00000000 HVML 00000000)
    [ 0.012559] ACPI: HPET 0x00000000FC00A560 000038 (v01 Xen HVM 00000000 HVML 00000000)
    [ 0.012562] ACPI: WAET 0x00000000FC00A5A0 000028 (v01 Xen HVM 00000000 HVML 00000000)
    [ 0.012566] ACPI: SSDT 0x00000000FC00A5D0 000031 (v02 Xen HVM 00000000 INTL 20240322)
    [ 0.012574] ACPI: SSDT 0x00000000FC00A610 000031 (v02 Xen HVM 00000000 INTL 20240322)
    [ 0.012578] ACPI: Reserving FACP table memory at [mem 0xfc00a370-0xfc00a463]
    [ 0.012579] ACPI: Reserving DSDT table memory at [mem 0xfc001040-0xfc00a2e2]
    [ 0.012580] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f]
    [ 0.012581] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f]
    [ 0.012582] ACPI: Reserving APIC table memory at [mem 0xfc00a470-0xfc00a4df]
    [ 0.012583] ACPI: Reserving HPET table memory at [mem 0xfc00a560-0xfc00a597]
    [ 0.012584] ACPI: Reserving WAET table memory at [mem 0xfc00a5a0-0xfc00a5c7]
    [ 0.012584] ACPI: Reserving SSDT table memory at [mem 0xfc00a5d0-0xfc00a600]
    [ 0.012585] ACPI: Reserving SSDT table memory at [mem 0xfc00a610-0xfc00a640]
    [ 0.021354] No NUMA configuration found
    [ 0.021359] Faking a node at [mem 0x0000000000000000-0x0000000011bedfff]
    [ 0.021375] NODE_DATA(0) allocated [mem 0x11493280-0x114bdfff]
    [ 0.021646] Zone ranges:
    [ 0.021647] DMA [mem 0x0000000000001000-0x0000000000ffffff]
    [ 0.021650] DMA32 [mem 0x0000000001000000-0x0000000011bedfff]
    [ 0.021651] Normal empty
    [ 0.021653] Device empty
    [ 0.021653] Movable zone start for each node
    [ 0.021656] Early memory node ranges
    [ 0.021657] node 0: [mem 0x0000000000001000-0x000000000009efff]
    [ 0.021658] node 0: [mem 0x0000000000100000-0x0000000011bedfff]
    [ 0.021660] Initmem setup node 0 [mem 0x0000000000001000-0x0000000011bedfff]
    [ 0.021675] On node 0, zone DMA: 1 pages in unavailable ranges
    [ 0.021701] On node 0, zone DMA: 97 pages in unavailable ranges
    [ 0.022337] On node 0, zone DMA32: 25618 pages in unavailable ranges
    [ 0.047413] ACPI: PM-Timer IO Port: 0xb008
    [ 0.047509] IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-47
    [ 0.047515] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
    [ 0.047518] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 low level)
    [ 0.047519] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 low level)
    [ 0.047521] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 low level)
    [ 0.047526] ACPI: Using ACPI (MADT) for SMP configuration information
    [ 0.047527] ACPI: HPET id: 0x8086a201 base: 0xfed00000
    [ 0.047533] TSC deadline timer available
    [ 0.047539] CPU topo: Max. logical packages: 1
    [ 0.047540] CPU topo: Max. logical dies: 1
    [ 0.047540] CPU topo: Max. dies per package: 1
    [ 0.047546] CPU topo: Max. threads per core: 1
    [ 0.047546] CPU topo: Num. cores per package: 2
    [ 0.047547] CPU topo: Num. threads per package: 2
    [ 0.047548] CPU topo: Allowing 2 present CPUs plus 0 hotplug CPUs
    [ 0.047560] [mem 0x11c00000-0xfbffffff] available for PCI devices
    [ 0.047562] Booting paravirtualized kernel on Xen HVM
    [ 0.047565] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
    [ 0.057479] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:2 nr_cpu_ids:2 nr_node_ids:1
    [ 0.057741] percpu: Embedded 84 pages/cpu s221184 r8192 d114688 u1048576
    [ 0.057748] pcpu-alloc: s221184 r8192 d114688 u1048576 alloc=1*2097152
    [ 0.057751] pcpu-alloc: [0] 0 1
    [ 0.057781] xen: PV spinlocks enabled
    [ 0.057784] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
    [ 0.057786] Kernel command line: systemd.machine_id=851fbd4ae36145c3a5cdbf2da175702b root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_privcmd.unrestricted xen_scrub_pages=0 selinux=1 security=selinux
    [ 0.058894] Booted with the nomodeset parameter. Only the system framebuffer will be available
    [ 0.059056] Unknown kernel command line parameters “rd_NO_PLYMOUTH”, will be passed to user space.
    [ 0.059063] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes
    [ 0.059096] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [ 0.059111] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [ 0.059183] Fallback order for Node 0: 0
    [ 0.059187] Built 1 zonelists, mobility grouping on. Total pages: 72588
    [ 0.059188] Policy zone: DMA32
    [ 0.059431] mem auto-init: stack:all(zero), heap alloc:on, heap free:on
    [ 0.059433] mem auto-init: clearing system memory may take some time…
    [ 0.214984] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [ 0.215105] Kernel/User page tables isolation: enabled
    [ 0.233004] ftrace: allocating 61705 entries in 244 pages
    [ 0.233009] ftrace: allocated 244 pages with 5 groups
    [ 0.233158] Dynamic Preempt: full
    [ 0.233277] rcu: Preemptible hierarchical RCU implementation.
    [ 0.233278] rcu: RCU event tracing is enabled.
    [ 0.233279] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=2.
    [ 0.233281] Trampoline variant of Tasks RCU enabled.
    [ 0.233281] Rude variant of Tasks RCU enabled.
    [ 0.233282] Tracing variant of Tasks RCU enabled.
    [ 0.233283] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
    [ 0.233284] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [ 0.233296] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
    [ 0.233298] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
    [ 0.233300] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
    [ 0.244797] NR_IRQS: 524544, nr_irqs: 512, preallocated irqs: 16
    [ 0.244887] xen:events: Using FIFO-based ABI
    [ 0.244910] xen:events: Xen HVM callback vector for event delivery is enabled
    [ 0.245094] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [ 0.245574] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
    [ 0.545342] Console: colour VGA+ 80x25
    [ 0.545391] printk: legacy console [hvc0] enabled
    [ 0.550209] ACPI: Core revision 20250807
    [ 0.550833] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 30580167144 ns
    [ 0.550978] APIC: Switch to symmetric I/O mode setup
    [ 0.552019] x2apic enabled
    [ 0.553518] APIC: Switched APIC routing to: physical x2apic
    [ 0.561821] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
    [ 0.566182] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x25647e07037, max_idle_ns: 440795273876 ns
    [ 0.566232] Calibrating delay loop (skipped), value calculated using timer frequency.. 5188.21 BogoMIPS (lpj=2594108)
    [ 0.566486] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
    [ 0.566505] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
    [ 0.566539] mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
    [ 0.566576] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
    [ 0.566602] Spectre V2 : Mitigation: Retpolines
    [ 0.566617] MDS: Mitigation: Clear CPU buffers
    [ 0.566633] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
    [ 0.566658] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
    [ 0.566679] Spectre V2 : Enabling Restricted Speculation for firmware calls
    [ 0.566699] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
    [ 0.566741] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
    [ 0.566764] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
    [ 0.566782] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
    [ 0.566801] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
    [ 0.566820] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using ‘standard’ format.
    [ 0.595985] Freeing SMP alternatives memory: 56K
    [ 0.596021] pid_max: default: 32768 minimum: 301
    [ 0.596613] LSM: initializing lsm=lockdown,capability,landlock,yama,selinux,ima,evm
    [ 0.596939] landlock: Up and running.
    [ 0.596953] Yama: becoming mindful.
    [ 0.596972] SELinux: Initializing.
    [ 0.598613] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
    [ 0.598640] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
    [ 0.600138] clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
    [ 0.600177] Xen: using vcpuop timer interface
    [ 0.600187] installing Xen timer for CPU 0
    [ 0.600224] smpboot: CPU0: Intel(R) Core™ i5-3320M CPU @ 2.60GHz (family: 0x6, model: 0x3a, stepping: 0x9)
    [ 0.600224] cpu 0 spinlock event irq 52
    [ 0.600224] Performance Events: unsupported CPU family 6 model 58 no PMU driver, software events only.
    [ 0.600224] signal: max sigframe size: 1776
    [ 0.600224] rcu: Hierarchical SRCU implementation.
    [ 0.600224] rcu: Max phase no-delay instances is 400.
    [ 0.600224] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [ 0.600224] NMI watchdog: Perf NMI watchdog permanently disabled
    [ 0.600224] smp: Bringing up secondary CPUs …
    [ 0.600224] installing Xen timer for CPU 1
    [ 0.600224] smpboot: x86: Booting SMP configuration:
    [ 0.600224] … node #0, CPUs: #1
    [ 0.600224] cpu 1 spinlock event irq 57
    [ 0.600224] smp: Brought up 1 node, 2 CPUs
    [ 0.600224] smpboot: Total of 2 processors activated (10376.43 BogoMIPS)
    [ 0.600224] Memory: 209276K/290352K available (21618K kernel code, 4462K rwdata, 10956K rodata, 5636K init, 5264K bss, 75088K reserved, 0K cma-reserved)
    [ 0.600224] devtmpfs: initialized
    [ 0.600224] x86/mm: Memory block size: 128MB
    [ 0.600224] ACPI: PM: Registering ACPI NVS region [mem 0xfc000000-0xfc00afff] (45056 bytes)
    [ 0.600224] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [ 0.600224] posixtimers hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [ 0.600224] futex hash table entries: 512 (32768 bytes on 1 NUMA nodes, total 32 KiB, linear).
    [ 0.600224] pinctrl core: initialized pinctrl subsystem
    [ 0.600224] PM: RTC time: 10:44:45, date: 2026-07-24
    [ 0.600224] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [ 0.600224] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [ 0.600224] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [ 0.600224] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [ 0.600224] audit: initializing netlink subsys (disabled)
    [ 0.600224] thermal_sys: Registered thermal governor ‘fair_share’
    [ 0.600224] thermal_sys: Registered thermal governor ‘bang_bang’
    [ 0.600224] thermal_sys: Registered thermal governor ‘step_wise’
    [ 0.600224] thermal_sys: Registered thermal governor ‘user_space’
    [ 0.600224] cpuidle: using governor menu
    [ 0.600224] audit: type=2000 audit(1784889885.615:1): state=initialized audit_enabled=0 res=1
    [ 0.600224] PCI: Using configuration type 1 for base access
    [ 0.600224] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
    [ 0.600224] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [ 0.600224] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
    [ 0.600224] raid6: skipped pq benchmark and selected sse2x4
    [ 0.600224] raid6: using ssse3x2 recovery algorithm
    [ 0.600224] ACPI: Added _OSI(Module Device)
    [ 0.600224] ACPI: Added _OSI(Processor Device)
    [ 0.600224] ACPI: Added _OSI(Processor Aggregator Device)
    [ 0.600224] ACPI: 3 ACPI AML tables successfully acquired and loaded
    [ 0.600224] ACPI: Interpreter enabled
    [ 0.600224] ACPI: PM: (supports S0 S3 S5)
    [ 0.600224] ACPI: Using IOAPIC for interrupt routing
    [ 0.600224] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
    [ 0.600224] PCI: Ignoring E820 reservations for host bridge windows
    [ 0.600224] ACPI: Enabled 2 GPEs in block 00 to 0F
    [ 0.600224] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
    [ 0.600224] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI EDR HPX-Type3]
    [ 0.600224] acpi PNP0A03:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
    [ 0.600224] acpi PNP0A03:00: fail to add MMCONFIG information, can’t access extended configuration space under this bridge
    [ 0.600224] PCI host bridge to bus 0000:00
    [ 0.600224] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
    [ 0.600224] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
    [ 0.600224] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
    [ 0.600224] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfbffffff window]
    [ 0.600224] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 0.600224] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000 conventional PCI endpoint
    [ 0.600224] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100 conventional PCI endpoint
    [ 0.600224] pci 0000:00:01.1: [8086:7010] type 00 class 0x010180 conventional PCI endpoint
    [ 0.600224] pci 0000:00:01.1: BAR 4 [io 0x0000-0x000f]
    [ 0.600224] pci 0000:00:01.1: BAR 0 [io 0x01f0-0x01f7]: legacy IDE quirk
    [ 0.600224] pci 0000:00:01.1: BAR 1 [io 0x03f6]: legacy IDE quirk
    [ 0.600224] pci 0000:00:01.1: BAR 2 [io 0x0170-0x0177]: legacy IDE quirk
    [ 0.600224] pci 0000:00:01.1: BAR 3 [io 0x0376]: legacy IDE quirk
    [ 0.600224] pci 0000:00:01.3: [8086:7113] type 00 class 0x068000 conventional PCI endpoint
    [ 0.600224] pci 0000:00:01.3: quirk: [io 0xb000-0xb03f] claimed by PIIX4 ACPI
    [ 0.600224] pci 0000:00:01.3: quirk: [io 0xb100-0xb10f] claimed by PIIX4 SMB
    [ 0.600224] pci 0000:00:02.0: [5853:0001] type 00 class 0xff8000 conventional PCI endpoint
    [ 0.600224] pci 0000:00:02.0: BAR 0 [io 0xc000-0xc0ff]
    [ 0.600224] pci 0000:00:02.0: BAR 1 [mem 0xf0000000-0xf0ffffff pref]
    [ 0.600224] pci 0000:00:04.0: [1234:1111] type 00 class 0x030000 conventional PCI endpoint
    [ 0.600224] pci 0000:00:04.0: BAR 0 [mem 0xf1000000-0xf1ffffff pref]
    [ 0.600224] pci 0000:00:04.0: BAR 2 [mem 0xf2022000-0xf2022fff]
    [ 0.600224] pci 0000:00:04.0: ROM [mem 0xf2000000-0xf200ffff pref]
    [ 0.600224] pci 0000:00:04.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
    [ 0.600224] pci 0000:00:05.0: [8086:24cd] type 00 class 0x0c0320 conventional PCI endpoint
    [ 0.600224] pci 0000:00:05.0: BAR 0 [mem 0xf2023000-0xf2023fff]
    [ 0.600224] pci 0000:00:06.0: [8086:1e31] type 00 class 0x0c0330 conventional PCI endpoint
    [ 0.600224] pci 0000:00:06.0: BAR 0 [mem 0xf2010000-0xf201ffff 64bit]
    [ 0.600224] pci 0000:00:07.0: [8086:1e2d] type 00 class 0x0c0320 conventional PCI endpoint
    [ 0.600224] pci 0000:00:07.0: BAR 0 [mem 0xf2024000-0xf2024fff]
    [ 0.600224] pci 0000:00:08.0: [8086:1e26] type 00 class 0x0c0320 conventional PCI endpoint
    [ 0.600224] pci 0000:00:08.0: BAR 0 [mem 0xf2025000-0xf2025fff]
    [ 0.600224] ACPI: PCI: Interrupt link LNKA configured for IRQ 5
    [ 0.600224] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
    [ 0.600224] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
    [ 0.600224] ACPI: PCI: Interrupt link LNKD configured for IRQ 5
    [ 0.600224] xen:balloon: Initialising balloon driver
    [ 0.600224] iommu: Default domain type: Translated
    [ 0.600224] iommu: DMA domain TLB invalidation policy: lazy mode
    [ 0.600224] SCSI subsystem initialized
    [ 0.600224] libata version 3.00 loaded.
    [ 0.600224] ACPI: bus type USB registered
    [ 0.600224] usbcore: registered new interface driver usbfs
    [ 0.600224] usbcore: registered new interface driver hub
    [ 0.600224] usbcore: registered new device driver usb
    [ 0.600224] pps_core: LinuxPPS API ver. 1 registered
    [ 0.600224] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
    [ 0.600224] PTP clock support registered
    [ 0.600224] EDAC MC: Ver: 3.0.0
    [ 0.600224] NetLabel: Initializing
    [ 0.600224] NetLabel: domain hash size = 128
    [ 0.600224] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
    [ 0.600224] NetLabel: unlabeled traffic allowed by default
    [ 0.600224] mctp: management component transport protocol core
    [ 0.600224] NET: Registered PF_MCTP protocol family
    [ 0.600224] PCI: Using ACPI for IRQ routing
    [ 0.600224] PCI: pci_cache_line_size set to 64 bytes
    [ 0.600224] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
    [ 0.600224] e820: reserve RAM buffer [mem 0x11bee000-0x13ffffff]
    [ 0.600224] pci 0000:00:04.0: vgaarb: setting as boot VGA device
    [ 0.600224] pci 0000:00:04.0: vgaarb: bridge control possible
    [ 0.600224] pci 0000:00:04.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
    [ 0.600224] vgaarb: loaded
    [ 0.600224] hpet: 3 channels of 0 reserved for per-cpu timers
    [ 0.600224] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
    [ 0.600224] hpet0: 3 comparators, 64-bit 62.500000 MHz counter
    [ 0.600224] clocksource: Switched to clocksource xen
    [ 0.600224] VFS: Disk quotas dquot_6.6.0
    [ 0.600224] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [ 0.600224] pnp: PnP ACPI init
    [ 0.600224] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
    [ 0.600224] system 00:01: [io 0x08a0-0x08a3] has been reserved
    [ 0.600224] system 00:01: [io 0x0cc0-0x0ccf] has been reserved
    [ 0.600224] system 00:01: [io 0x04d0-0x04d1] has been reserved
    [ 0.600224] pnp 00:05: [dma 2]
    [ 0.600224] system 00:06: [io 0xae00-0xae0f] has been reserved
    [ 0.600224] system 00:06: [io 0xb044-0xb047] has been reserved
    [ 0.600224] pnp: PnP ACPI: found 7 devices
    [ 0.623620] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
    [ 0.623796] NET: Registered PF_INET protocol family
    [ 0.623861] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [ 0.624419] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
    [ 0.624447] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [ 0.624542] TCP established hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [ 0.624570] TCP bind hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [ 0.624611] TCP: Hash tables configured (established 2048 bind 2048)
    [ 0.624689] MPTCP token hash table entries: 256 (order: 1, 6144 bytes, linear)
    [ 0.624884] UDP hash table entries: 256 (order: 2, 16384 bytes, linear)
    [ 0.624909] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes, linear)
    [ 0.625052] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [ 0.625080] NET: Registered PF_XDP protocol family
    [ 0.625149] pci 0000:00:01.1: BAR 4 [io 0x1000-0x100f]: assigned
    [ 0.625455] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
    [ 0.625479] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
    [ 0.625499] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
    [ 0.625518] pci_bus 0000:00: resource 7 [mem 0xf0000000-0xfbffffff window]
    [ 0.625792] pci 0000:00:01.0: PIIX3: Enabling Passive Release
    [ 0.626070] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
    [ 0.668980] pci 0000:00:07.0: quirk_usb_early_handoff+0x0/0x180 took 26162 usecs
    [ 0.690535] pci 0000:00:08.0: quirk_usb_early_handoff+0x0/0x180 took 19447 usecs
    [ 0.691556] PCI: CLS 0 bytes, default 64
    [ 0.692814] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x25647e07037, max_idle_ns: 440795273876 ns
    [ 0.692901] clocksource: Switched to clocksource tsc
    [ 0.693427] Trying to unpack rootfs image as initramfs…
    [ 0.701294] Initialise system trusted keyrings
    [ 0.701329] Key type blacklist registered
    [ 0.702251] workingset: timestamp_bits=36 max_order=16 bucket_order=0
    [ 0.706104] integrity: Platform Keyring initialized
    [ 0.706161] integrity: Machine keyring initialized
    [ 0.706360] cryptd: max_cpu_qlen set to 1000
    [ 0.725816] NET: Registered PF_ALG protocol family
    [ 0.725858] xor: automatically using best checksumming function avx
    [ 0.725882] Key type asymmetric registered
    [ 0.725895] Asymmetric key parser ‘x509’ registered
    [ 0.726420] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [ 0.726523] io scheduler mq-deadline registered
    [ 0.726542] io scheduler kyber registered
    [ 0.726590] io scheduler bfq registered
    [ 0.727897] atomic64_test: passed for x86-64 platform with CX8 and with SSE
    [ 0.728190] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
    [ 0.728280] ACPI: button: Power Button [PWRF]
    [ 0.728340] input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input1
    [ 0.728398] ACPI: button: Sleep Button [SLPF]
    [ 0.769890] xen:grant_table: Grant tables using version 1 layout
    [ 0.769953] Grant table initialized
    [ 0.771486] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
    [ 0.774372] Non-volatile memory driver v1.3
    [ 0.774399] Linux agpgart interface v0.103
    [ 0.776568] ACPI: bus type drm_connector registered
    [ 0.778232] ata_piix 0000:00:01.1: enabling device (0000 → 0001)
    [ 0.788070] scsi host0: ata_piix
    [ 0.788282] scsi host1: ata_piix
    [ 0.788335] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0x1000 irq 14 lpm-pol 0
    [ 0.788361] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0x1008 irq 15 lpm-pol 0
    [ 0.795817] Freeing initrd memory: 7304K
    [ 0.798009] usbcore: registered new interface driver usbserial_generic
    [ 0.798040] usbserial: USB Serial support registered for generic
    [ 0.798107] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
    [ 0.803830] serio: i8042 KBD port at 0x60,0x64 irq 1
    [ 0.803911] serio: i8042 AUX port at 0x60,0x64 irq 12
    [ 0.804076] mousedev: PS/2 mouse device common for all mice
    [ 0.807109] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
    [ 0.809220] rtc_cmos 00:02: registered as rtc0
    [ 0.809292] rtc_cmos 00:02: setting system clock to 2026-07-24T10:44:46 UTC (1784889886)
    [ 0.809364] rtc_cmos 00:02: alarms up to one day, 114 bytes nvram
    [ 0.809413] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
    [ 0.809464] device-mapper: uevent: version 1.0.3
    [ 0.810372] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
    [ 0.811126] intel_pstate: CPU model not supported
    [ 0.811295] hid: raw HID events driver (C) Jiri Kosina
    [ 0.811359] usbcore: registered new interface driver usbhid
    [ 0.811376] usbhid: USB HID core driver
    [ 0.811537] drop_monitor: Initializing network drop monitor service
    [ 0.811653] Initializing XFRM netlink socket
    [ 0.811795] NET: Registered PF_INET6 protocol family
    [ 0.813063] Segment Routing with IPv6
    [ 0.813080] RPL Segment Routing with IPv6
    [ 0.813102] In-situ OAM (IOAM) with IPv6
    [ 0.813154] mip6: Mobile IPv6
    [ 0.813170] NET: Registered PF_PACKET protocol family
    [ 0.815027] IPI shorthand broadcast: enabled
    [ 0.819015] sched_clock: Marking stable (513008835, 305129482)->(1814106873, -995968556)
    [ 0.823754] registered taskstats version 1
    [ 0.824447] Loading compiled-in X.509 certificates
    [ 0.841354] Loaded X.509 cert ‘Build time autogenerated kernel key: d511f44cbbeaa8c618d118c31fae922f93e4baa3’
    [ 0.850201] Demotion targets for Node 0: null
    [ 0.850225] page_owner is disabled
    [ 0.851796] Key type .fscrypt registered
    [ 0.851811] Key type fscrypt-provisioning registered
    [ 0.853656] Btrfs loaded, zoned=yes, fsverity=yes
    [ 0.853710] Key type big_key registered
    [ 0.855054] Key type encrypted registered
    [ 0.855077] ima: No TPM chip found, activating TPM-bypass!
    [ 0.855098] Loading compiled-in module X.509 certificates
    [ 0.855739] Loaded X.509 cert ‘Build time autogenerated kernel key: d511f44cbbeaa8c618d118c31fae922f93e4baa3’
    [ 0.857339] ima: Allocated hash algorithm: sha256
    [ 0.858240] ima: No architecture policies found
    [ 0.858279] evm: Initialising EVM extended attributes:
    [ 0.858296] evm: security.selinux
    [ 0.858308] evm: security.SMACK64 (disabled)
    [ 0.858323] evm: security.SMACK64EXEC (disabled)
    [ 0.858339] evm: security.SMACK64TRANSMUTE (disabled)
    [ 0.858354] evm: security.SMACK64MMAP (disabled)
    [ 0.858369] evm: security.apparmor
    [ 0.858381] evm: security.ima
    [ 0.858393] evm: security.capability
    [ 0.858405] evm: HMAC attrs: 0x1
    [ 0.886400] alg: No test for 842 (842-scomp)
    [ 0.931539] xenbus_probe_frontend: Device with no driver: device/vbd/51712
    [ 0.931575] xenbus_probe_frontend: Device with no driver: device/vbd/51728
    [ 0.931596] xenbus_probe_frontend: Device with no driver: device/vbd/51744
    [ 0.931615] xenbus_probe_frontend: Device with no driver: device/vbd/51760
    [ 0.931743] PM: Magic number: 2:554:730
    [ 0.931850] RAS: Correctable Errors collector initialized.
    [ 0.931905] clk: Disabling unused clocks
    [ 0.931918] PM: genpd: Disabling unused power domains
    [ 0.990293] Freeing unused decrypted memory: 2028K
    [ 0.991365] Freeing unused kernel image (initmem) memory: 5636K
    [ 0.991438] Write protecting the kernel read-only data: 34816k
    [ 0.991989] Freeing unused kernel image (text/rodata gap) memory: 908K
    [ 0.992390] Freeing unused kernel image (rodata/data gap) memory: 1332K
    [ 0.992444] Run /init as init process
    [ 0.992458] with arguments:
    [ 0.992460] /init
    [ 0.992461] rd_NO_PLYMOUTH
    [ 0.992462] with environment:
    [ 0.992463] HOME=/
    [ 0.992464] TERM=linux
    [ 0.999201] Invalid max_queues (4), will use default max: 2.
    [ 1.082248] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
    [ 1.106412] xvda: xvda1 xvda2 xvda3
    [ 1.119841] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
    [ 1.125477] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
    [ 1.131069] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
    [ 1.564015] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input4
    [ 2.435404] xvdc: xvdc1 xvdc3
    [ 2.659167] random: crng init done
    [ 2.797668] EXT4-fs (xvda3): mounted filesystem 2cb6159b-5261-4ea9-acc5-a06748c96529 r/w with ordered data mode. Quota mode: none.
    [ 2.802894] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem
    [ 2.804537] EXT4-fs (xvdd): mounted filesystem 629716e5-8a52-40e5-9fbb-49e8e08a5812 ro with ordered data mode. Quota mode: none.
    [ 2.926578] audit: type=1404 audit(1784889888.616:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 enabled=1 old-enabled=1 lsm=selinux res=1
    [ 2.961430] SELinux: Permission firmware_load in class system not defined in policy.
    [ 2.961473] SELinux: Permission kexec_image_load in class system not defined in policy.
    [ 2.961496] SELinux: Permission kexec_initramfs_load in class system not defined in policy.
    [ 2.961829] SELinux: Permission policy_load in class system not defined in policy.
    [ 2.961853] SELinux: Permission x509_certificate_load in class system not defined in policy.
    [ 2.961954] SELinux: Permission allowed in class io_uring not defined in policy.
    [ 2.961976] SELinux: the above unknown classes and permissions will be allowed
    [ 2.964078] SELinux: policy capability network_peer_controls=1
    [ 2.964103] SELinux: policy capability open_perms=1
    [ 2.964117] SELinux: policy capability extended_socket_class=1
    [ 2.964160] SELinux: policy capability always_check_network=0
    [ 2.964188] SELinux: policy capability cgroup_seclabel=1
    [ 2.964203] SELinux: policy capability nnp_nosuid_transition=1
    [ 2.964222] SELinux: policy capability genfs_seclabel_symlinks=1
    [ 2.964240] SELinux: policy capability ioctl_skip_cloexec=0
    [ 2.964259] SELinux: policy capability userspace_initial_context=0
    [ 2.964278] SELinux: policy capability netlink_xperm=0
    [ 2.964302] SELinux: policy capability netif_wildcard=0
    [ 2.964547] SELinux: policy capability genfs_seclabel_wildcard=0
    [ 2.964575] SELinux: policy capability functionfs_seclabel=0
    [ 2.990492] audit: type=1403 audit(1784889888.680:3): auid=4294967295 ses=4294967295 lsm=selinux res=1
    [ 2.992195] systemd[1]: Successfully loaded SELinux policy in 66.076ms.
    [ 3.426223] systemd[1]: Relabeled /dev/, /dev/shm/, /run/ in 7.375ms.
    [ 3.769428] systemd[1]: systemd 258.9-1.fc43 running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA +IPE +SMACK +SECCOMP -GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP +SYSVINIT +LIBARCHIVE)
    [ 3.769536] systemd[1]: Detected virtualization xen.
    [ 3.769568] systemd[1]: Detected architecture x86-64.
    [ 3.810260] systemd[1]: No hostname configured, using default hostname.
    [ 3.810399] systemd[1]: Hostname set to .
    [ 3.884890] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
    [ 3.979112] zram: Added device: zram0
    [ 4.273387] systemd[1]: /usr/lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [ 4.312353] systemd[1]: Queued start job for default target multi-user.target.
    [ 4.330383] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
    [ 4.331422] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
    [ 4.332178] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
    [ 4.332956] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
    [ 4.333709] systemd[1]: Created slice system-systemd\x2dzram\x2dsetup.slice - Slice /system/systemd-zram-setup.
    [ 4.334306] systemd[1]: Created slice user.slice - User and Session Slice.
    [ 4.334564] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
    [ 4.334771] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
    [ 4.335585] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
    [ 4.335731] systemd[1]: Expecting device dev-hvc0.device - /dev/hvc0…
    [ 4.335850] systemd[1]: Expecting device dev-xvdb.device - /dev/xvdb…
    [ 4.335942] systemd[1]: Expecting device dev-xvdc1.device - /dev/xvdc1…
    [ 4.336033] systemd[1]: Expecting device dev-zram0.device - /dev/zram0…
    [ 4.336150] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
    [ 4.336266] systemd[1]: Reached target imports.target - Image Downloads.
    [ 4.336366] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
    [ 4.336617] systemd[1]: Reached target remote-fs.target - Remote File Systems.
    [ 4.336720] systemd[1]: Reached target slices.target - Slice Units.
    [ 4.336842] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
    [ 4.339055] systemd[1]: Listening on systemd-ask-password.socket - Query the User Interactively for a Password.
    [ 4.342052] systemd[1]: Listening on systemd-coredump.socket - Process Core Dump Socket.
    [ 4.477393] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
    [ 4.479745] systemd[1]: Listening on systemd-factory-reset.socket - Factory Reset Management.
    [ 4.480723] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
    [ 4.481411] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
    [ 4.481951] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
    [ 4.482168] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
    [ 4.482234] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
    [ 4.482844] systemd[1]: Listening on systemd-resolved-monitor.socket - Resolve Monitor Varlink Socket.
    [ 4.483200] systemd[1]: Listening on systemd-resolved-varlink.socket - Resolve Service Varlink Socket.
    [ 4.484844] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
    [ 4.485535] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
    [ 4.485981] systemd[1]: Listening on systemd-udevd-varlink.socket - udev Varlink Socket.
    [ 4.488679] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System…
    [ 4.490395] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System…
    [ 4.492574] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System…
    [ 4.498444] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System…
    [ 4.501068] systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early…
    [ 4.502771] systemd[1]: fips-crypto-policy-overlay.service - Bind-mount FIPS crypto-policy in FIPS mode skipped, unmet condition check ConditionKernelCommandLine=fips=1
    [ 4.507049] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes…
    [ 4.507306] systemd[1]: modprobe@configfs.service - Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
    [ 4.509495] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System…
    [ 4.510764] systemd[1]: modprobe@dm_mod.service - Load Kernel Module dm_mod skipped, unmet condition check ConditionKernelModuleLoaded=!dm_mod
    [ 4.510871] systemd[1]: modprobe@drm.service - Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
    [ 4.512698] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse…
    [ 4.676714] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop…
    [ 4.677059] systemd[1]: systemd-boot-clear-sysfail.service - Clear SysFail Entry If The Boot Is Successful skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/LoaderEntrySysFail-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f
    [ 4.677220] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
    [ 4.680543] systemd[1]: Starting systemd-journald.service - Journal Service…
    [ 4.687490] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules…
    [ 4.689901] systemd[1]: Starting systemd-network-generator.service - Generate Network Units from Kernel Command Line…
    [ 4.690015] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
    [ 4.690194] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
    [ 4.692996] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials…
    [ 4.697057] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices…
    [ 4.738894] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
    [ 4.749211] loop: module loaded
    [ 4.759397] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully…
    [ 4.760246] Adding 1048572k swap on /dev/xvdc1. Priority:-2 extents:1 across:1048572k SS
    [ 4.768767] systemd[1]: Condition check resulted in dev-xvdc1.swap - /dev/xvdc1 being skipped.
    [ 4.768883] systemd[1]: Unnecessary job was removed for dev-xvdc1.device - /dev/xvdc1.
    [ 4.782806] i2c_dev: i2c /dev entries driver
    [ 4.785368] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
    [ 4.785850] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
    [ 4.786732] fuse: init (API version 7.45)
    [ 4.791541] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
    [ 4.791927] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
    [ 4.793102] systemd[1]: dev-xvdc1-swap.service: Deactivated successfully.
    [ 4.804932] xen:xen_evtchn: Event-channel device installed
    [ 4.805572] systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early.
    [ 4.808084] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
    [ 4.808569] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [ 4.808857] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
    [ 4.809611] systemd[1]: modprobe@loop.service: Deactivated successfully.
    [ 4.809869] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
    [ 4.810941] systemd[1]: Finished systemd-network-generator.service - Generate Network Units from Kernel Command Line.
    [ 4.811845] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
    [ 4.812755] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
    [ 4.817605] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems…
    [ 4.818497] systemd[1]: systemd-repart.service - Repartition Root Disk skipped, no trigger condition checks were met.
    [ 4.853523] systemd-journald[233]: Collecting audit messages is enabled.
    [ 4.873693] EXT4-fs (xvda3): re-mounted 2cb6159b-5261-4ea9-acc5-a06748c96529.
    [ 4.878502] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
    [ 4.879174] audit: type=1130 audit(1784889890.568:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-remount-fs comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
    [ 4.882784] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
    [ 4.882898] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
    [ 4.912433] systemd[1]: Started systemd-journald.service - Journal Service.
    [ 4.912805] audit: type=1130 audit(1784889890.602:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-journald comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
    [ 4.968685] Rounding down aligned max_sectors from 4294967295 to 4294967288
    [ 4.969051] db_root: cannot open: /etc/target
    [ 5.000864] systemd-journald[233]: Received client request to flush runtime journal.
    [ 5.052462] audit: type=1130 audit(1784889890.742:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-modules-load comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
    [ 5.080846] audit: type=1130 audit(1784889890.770:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-journal-flush comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
    [ 5.101762] audit: type=1130 audit(1784889890.791:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-tmpfiles-setup-dev-early comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
    [ 5.151903] audit: type=1130 audit(1784889890.841:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-udev-trigger comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
    [ 5.162044] audit: type=1130 audit(1784889890.851:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-sysctl comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
    [ 6.388534] kauditd_printk_skb: 8 callbacks suppressed
    [ 6.388538] audit: type=1334 audit(1784889892.078:19): prog-id=20 op=LOAD
    [ 6.388687] audit: type=1334 audit(1784889892.078:20): prog-id=15 op=UNLOAD
    [ 6.388792] audit: type=1334 audit(1784889892.078:21): prog-id=21 op=LOAD
    [ 6.388880] audit: type=1334 audit(1784889892.078:22): prog-id=22 op=LOAD
    [ 6.388933] audit: type=1334 audit(1784889892.078:23): prog-id=16 op=UNLOAD
    [ 6.388974] audit: type=1334 audit(1784889892.078:24): prog-id=17 op=UNLOAD
    [ 6.389538] audit: type=1334 audit(1784889892.079:25): prog-id=23 op=LOAD
    [ 6.389625] audit: type=1334 audit(1784889892.079:26): prog-id=24 op=LOAD
    [ 6.389681] audit: type=1334 audit(1784889892.079:27): prog-id=18 op=UNLOAD
    [ 6.389726] audit: type=1334 audit(1784889892.079:28): prog-id=19 op=UNLOAD
    [ 6.517969] piix4_smbus 0000:00:01.3: SMBus Host Controller not enabled!
    [ 6.594701] ehci-pci 0000:00:05.0: EHCI Host Controller
    [ 6.596320] ehci-pci 0000:00:05.0: new USB bus registered, assigned bus number 1
    [ 6.620351] ehci-pci 0000:00:05.0: irq 39, io mem 0xf2023000
    [ 6.631126] ehci-pci 0000:00:05.0: USB 2.0 started, EHCI 1.00
    [ 6.660233] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
    [ 6.660265] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 6.660289] usb usb1: Product: EHCI Host Controller
    [ 6.660306] usb usb1: Manufacturer: Linux 6.18.31-1.qubes.fc41.x86_64 ehci_hcd
    [ 6.660329] usb usb1: SerialNumber: 0000:00:05.0
    [ 6.700834] FDC 0 is a S82078B
    [ 6.748893] hub 1-0:1.0: USB hub found
    [ 6.748936] hub 1-0:1.0: 6 ports detected
    [ 6.777248] ehci-pci 0000:00:07.0: EHCI Host Controller
    [ 6.777468] ehci-pci 0000:00:07.0: new USB bus registered, assigned bus number 2
    [ 6.791612] ehci-pci 0000:00:07.0: Enabling legacy PCI PM
    [ 6.808374] ehci-pci 0000:00:07.0: irq 44, io mem 0xf2024000
    [ 6.814179] ehci-pci 0000:00:07.0: USB 2.0 started, EHCI 1.00
    [ 6.814290] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
    [ 6.814316] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 6.814340] usb usb2: Product: EHCI Host Controller
    [ 6.814356] usb usb2: Manufacturer: Linux 6.18.31-1.qubes.fc41.x86_64 ehci_hcd
    [ 6.814379] usb usb2: SerialNumber: 0000:00:07.0
    [ 6.814562] hub 2-0:1.0: USB hub found
    [ 6.814586] hub 2-0:1.0: 3 ports detected
    [ 6.816781] ehci-pci 0000:00:08.0: EHCI Host Controller
    [ 6.818158] ehci-pci 0000:00:08.0: new USB bus registered, assigned bus number 3
    [ 6.830248] ehci-pci 0000:00:08.0: Enabling legacy PCI PM
    [ 6.836492] ehci-pci 0000:00:08.0: irq 17, io mem 0xf2025000
    [ 6.842169] ehci-pci 0000:00:08.0: USB 2.0 started, EHCI 1.00
    [ 6.842523] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
    [ 6.842552] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 6.842577] usb usb3: Product: EHCI Host Controller
    [ 6.842593] usb usb3: Manufacturer: Linux 6.18.31-1.qubes.fc41.x86_64 ehci_hcd
    [ 6.842616] usb usb3: SerialNumber: 0000:00:08.0
    [ 6.842793] hub 3-0:1.0: USB hub found
    [ 6.842816] hub 3-0:1.0: 3 ports detected
    [ 6.848362] input: PC Speaker as /devices/platform/pcspkr/input/input5
    [ 6.877872] xhci_hcd 0000:00:06.0: xHCI Host Controller
    [ 6.879519] xhci_hcd 0000:00:06.0: new USB bus registered, assigned bus number 4
    [ 6.880624] xhci_hcd 0000:00:06.0: hcc params 0x200071a1 hci version 0x100 quirks 0x000000000000b930
    [ 6.922370] xhci_hcd 0000:00:06.0: xHCI Host Controller
    [ 6.929793] xhci_hcd 0000:00:06.0: new USB bus registered, assigned bus number 5
    [ 6.929833] xhci_hcd 0000:00:06.0: Host supports USB 3.0 SuperSpeed
    [ 6.930097] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
    [ 6.930126] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 6.930174] usb usb4: Product: xHCI Host Controller
    [ 6.930191] usb usb4: Manufacturer: Linux 6.18.31-1.qubes.fc41.x86_64 xhci-hcd
    [ 6.930214] usb usb4: SerialNumber: 0000:00:06.0
    [ 6.935042] hub 4-0:1.0: USB hub found
    [ 6.935084] hub 4-0:1.0: 4 ports detected
    [ 6.935339] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
    [ 6.935366] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 6.935390] usb usb5: Product: xHCI Host Controller
    [ 6.935406] usb usb5: Manufacturer: Linux 6.18.31-1.qubes.fc41.x86_64 xhci-hcd
    [ 6.935433] usb usb5: SerialNumber: 0000:00:06.0
    [ 6.936844] hub 5-0:1.0: USB hub found
    [ 6.938772] hub 5-0:1.0: 4 ports detected
    [ 7.022163] usb 1-1: new high-speed USB device number 2 using ehci-pci
    [ 7.054160] usb 2-1: new high-speed USB device number 2 using ehci-pci
    [ 7.086163] usb 3-1: new high-speed USB device number 2 using ehci-pci
    [ 7.171817] zram: Removed device: zram0
    [ 7.183391] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
    [ 7.183423] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [ 7.185076] hub 2-1:1.0: USB hub found
    [ 7.185588] hub 2-1:1.0: 6 ports detected
    [ 7.188778] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
    [ 7.188818] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
    [ 7.188842] usb 1-1: Product: QEMU USB Tablet
    [ 7.188858] usb 1-1: Manufacturer: QEMU
    [ 7.188871] usb 1-1: SerialNumber: 42
    [ 7.209463] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:05.0/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input6
    [ 7.210434] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:05.0-1/input0
    [ 7.215365] usb 3-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
    [ 7.215398] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [ 7.216908] hub 3-1:1.0: USB hub found
    [ 7.217378] hub 3-1:1.0: 8 ports detected
    [ 7.473202] usb 2-1.3: new full-speed USB device number 3 using ehci-pci
    [ 7.510636] usb 3-1.6: new full-speed USB device number 3 using ehci-pci
    [ 7.564115] usb 2-1.3: New USB device found, idVendor=147e, idProduct=2020, bcdDevice= 0.01
    [ 7.564121] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [ 7.564123] usb 2-1.3: Product: Biometric Coprocessor
    [ 7.564124] usb 2-1.3: Manufacturer: Auth
    [ 7.611195] usb 3-1.6: New USB device found, idVendor=08e6, idProduct=34ec, bcdDevice= 1.00
    [ 7.611201] usb 3-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [ 7.611203] usb 3-1.6: Product: GemPC Express
    [ 7.611205] usb 3-1.6: Manufacturer: Gemplus
    [ 7.633192] usb 2-1.4: new full-speed USB device number 4 using ehci-pci
    [ 7.725238] EXT4-fs (xvdb): mounted filesystem 417e50ac-a9b7-4485-a34c-886f0666a587 r/w without journal. Quota mode: none.
    [ 7.745119] usb 2-1.4: New USB device found, idVendor=0a5c, idProduct=21e6, bcdDevice= 1.12
    [ 7.745124] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 7.745127] usb 2-1.4: Product: BCM20702A0
    [ 7.745128] usb 2-1.4: Manufacturer: Broadcom Corp
    [ 7.745172] usb 2-1.4: SerialNumber: 446D57C2233F
    [ 7.820855] usb 2-1.6: new high-speed USB device number 5 using ehci-pci
    [ 7.954409] usb 2-1.6: New USB device found, idVendor=04f2, idProduct=b2ea, bcdDevice= 5.18
    [ 7.954416] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [ 7.954418] usb 2-1.6: Product: Integrated Camera
    [ 7.954419] usb 2-1.6: Manufacturer: Chicony Electronics Co., Ltd.
    [ 8.473622] mc: Linux media interface: v0.10
    [ 8.706972] videodev: Linux video capture interface: v2.00
    [ 9.374415] Bluetooth: Core ver 2.22
    [ 9.376297] NET: Registered PF_BLUETOOTH protocol family
    [ 9.376300] Bluetooth: HCI device and connection manager initialized
    [ 9.376305] Bluetooth: HCI socket layer initialized
    [ 9.376307] Bluetooth: L2CAP socket layer initialized
    [ 9.376318] Bluetooth: SCO socket layer initialized
    [ 9.421393] usbcore: registered new interface driver btusb
    [ 9.438413] uvcvideo 2-1.6:1.0: Found UVC 1.00 device Integrated Camera (04f2:b2ea)
    [ 9.466297] usbcore: registered new interface driver uvcvideo
    [ 9.556219] Bluetooth: hci0: BCM: chip id 63
    [ 9.558481] Bluetooth: hci0: BCM: features 0x07
    [ 9.574807] Bluetooth: hci0: BCM20702A
    [ 9.574814] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
    [ 9.624830] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
    [ 9.624860] Bluetooth: hci0: BCM: ‘brcm/BCM20702A1-0a5c-21e6.hcd’
    [ 9.624880] Bluetooth: hci0: BCM: ‘brcm/BCM-0a5c-21e6.hcd’
    [ 90.934444] usb 5-2: new SuperSpeed USB device number 2 using xhci_hcd
    [ 90.950243] usb 5-2: New USB device found, idVendor=4146, idProduct=166a, bcdDevice= 0.00
    [ 90.950285] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 90.950310] usb 5-2: Product: 32GB
    [ 90.950323] usb 5-2: Manufacturer: PRETEC
    [ 90.950344] usb 5-2: SerialNumber: 13081410332301021490
    [ 91.294421] usb-storage 5-2:1.0: USB Mass Storage device detected
    [ 91.296085] scsi host2: usb-storage 5-2:1.0
    [ 91.296250] usbcore: registered new interface driver usb-storage
    [ 91.305586] usbcore: registered new interface driver uas
    [ 92.359349] scsi 2:0:0:0: Direct-Access Generic USB Flash Drive 1.00 PQ: 0 ANSI: 4
    [ 92.361115] sd 2:0:0:0: Attached scsi generic sg0 type 0
    [ 92.361194] sd 2:0:0:0: [sda] 63700992 512-byte logical blocks: (32.6 GB/30.4 GiB)
    [ 92.361557] sd 2:0:0:0: [sda] Write Protect is off
    [ 92.361578] sd 2:0:0:0: [sda] Mode Sense: bf 00 00 00
    [ 92.361841] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
    [ 92.380743] sda: sda1 sda2 sda3
    [ 92.381093] sd 2:0:0:0: [sda] Attached SCSI removable disk
    [ 98.535341] usb 5-2: USB disconnect, device number 2
    [ 123.798331] usb 5-2: new SuperSpeed USB device number 3 using xhci_hcd
    [ 123.810933] usb 5-2: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
    [ 123.810994] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 123.811017] usb 5-2: Product: DataTraveler 3.0
    [ 123.811034] usb 5-2: Manufacturer: Kingston
    [ 123.811047] usb 5-2: SerialNumber: E0D55EA574E9E55068810D11
    [ 123.811611] usb-storage 5-2:1.0: USB Mass Storage device detected
    [ 123.814256] scsi host2: usb-storage 5-2:1.0
    [ 124.870979] scsi 2:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
    [ 124.872174] scsi 2:0:0:0: Attached scsi generic sg0 type 0
    [ 124.914740] sd 2:0:0:0: [sda] 242417664 512-byte logical blocks: (124 GB/116 GiB)
    [ 124.915914] sd 2:0:0:0: [sda] Write Protect is off
    [ 124.915935] sd 2:0:0:0: [sda] Mode Sense: 45 00 00 00
    [ 124.917012] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
    [ 124.931385] sda: sda1
    [ 124.932067] sd 2:0:0:0: [sda] Attached SCSI removable disk
Ok, so device is in sys-usb and you are not attaching it to any other qube.
How did you try to open the device? What did you do, type, click?
On sys-usb
lsusb
lsblk
df -Th
That’s a known “feature” (or bug, depending on how you see it) of R4.3 - see here .
Rant
OMG people, use the Forum search before posting!!! :neutral_face:
I didn’t find errors on dmesg.
The error message is different.
VS
“Failed to mount. Not authorized to perform operation (polkit authority not available and caller is not uid 0).”
Unsure if it is the same problem.
Ok got it now. I just had to append the drive to another qube and I can read it. I wasn’t aware of this change, but it definitely makes sense.
Sorry for wasting your time and thanks for your help. Ben​:folded_hands:t3::heart:
I still would like to know how did you try to open the device, was it via file manager or command-line? If command-line, can you show it?
I double clicked the icon named “removable” in the file manager (GUI) and there has been a pop-up windows displaying the message in my first post.
Can you try this and see if it fixes? 4.3: Disable minimal-usbvm service in sys-usb to use external storage. Would be nice to know if it is the same cause or different issues.
Since it seems to be part of the plan that QubesOS acts like this I’m fine.
I would prefer not to try, because my problem is solved. Thanks again for your help!
