I created a template for a qube that could print. This template was a copy of the basic whonix-workstation-17 qube. In this copy I enabled ‘cups’ installed the necessary drivers and set up for my printer. My printer was visible to the qube and seemed to configure properly but when I made an app qube (that is also configured properly) and it recognizes the printer it won’t print. Is there a change in the whonix-workstation-17 template that is different from the whonix-workstation-16 template? because following the exact same setup I was able to get the printer to work properly when using the 16 version. Also I was able to follow the same steps and get the printer working in a debian qube. Any insights would be helpful, thankyou in advance.
