When I try to open the settings for one of my templates and its AppVMs, I get the error shown in the below image. The text given under “Show Details” is also below. This does not happen in any other templates or AppVMs. I think it may be relevant that I recently added a custom Desktop Entry into /usr/share/applications and its binary to /usr/local/bin, but I removed them and the error still occurs. How do I solve this?
line: raise CalledProcessError(retcode, process.args,
func: run
line no.: 516
file: /usr/lib64/python3.8/subprocess.py
line: return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
func: check_output
line no.: 415
line: for line in subprocess.check_output(
func: fill_apps_list
line no.: 94
file: /usr/lib/python3.8/site-packages/qubesmanager/appmenu_select.py
line: self.fill_apps_list(template=None)
func: __init__
line no.: 61
line: self.app_list_manager = AppmenuSelectManager(self.vm, self.app_list)
func: __init__
line no.: 223
file: /usr/lib/python3.8/site-packages/qubesmanager/settings.py
line: window = window_class(qt_app, qubes_app)
func: run_synchronous
line no.: 558
file: /usr/lib/python3.8/site-packages/qubesmanager/utils.py
line: utils.run_synchronous(functools.partial(VMSettingsWindow, vm, args.tab))
func: main
line no.: 1502
line: load_entry_point('qubesmanager==4.1.23', 'console_scripts', 'qubes-vm-settings')()
func: <module>
line no.: 11
file: /usr/bin/qubes-vm-settings
