When Installing Qubes OS 4.2 in the Initial Setup most of the options are disabled and says whonix not available.
Then says there was a error in the initial setup and tells me to run a command, I run it and it gives me the error:
No Top file or master_tops data matches found
I only have the 4.2 ISO and I really don’t know how to fix this, I prefer to have reinstalling the last option.
There was only the dom0 qube, and no internet for some reason.
Tried to REINSTALL, nothing
Are you installing from a USB flash drive? If so, try checking it for errors both USB flash drive and the ISO file… this happened to me before and a faulty write of the ISO file to the USB flash drive caused the problem… Hope this helps… good luck!
Specify the exact command.
I didn’t reply in 1 week because I bought a new SSD and I am going to try again on the OLD SSD, let me try again and I send you the error
