Whenever I try fetching sources, it gives this error:
[user@work-qubesos qubes-builderv2]$ ./qb package fetch
16:49:37 [qb] Running stage 'fetch'
16:49:43 [qb.fetch.builder-rpm.fetch] copy-in (cmd): /usr/lib/qubes/qrexec-client-vm -- disp2451 qubesbuilder.FileCopyIn+-2Fbuilder-2Fplugins-2Ffetch /usr/lib/qubes/qfile-agent /home/user/qubes-builderv2/qubesbuilder/plugins/fetch
qfile-unpacker: Fatal error: Refusing to change to UID other than the caller's UID (error type: Success)
File "/usr/local/etc/qubes-rpc/qubesbuilder.FileCopyIn", line 75, in <module>
main()
File "/usr/local/etc/qubes-rpc/qubesbuilder.FileCopyIn", line 64, in main
subprocess.run(
File "/usr/lib64/python3.12/subprocess.py", line 571, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['qfile-unpacker', '--allow-all-names', '--allow-unsafe-symlinks', '1000', '/builder/incoming']' returned non-zero exit status 1.
EOF
I have followed all the instructions for installing dependencies and setting the DispVM as default for work-qubesos.
I’ve properly followed all the steps and I even copied the policy file as well. I’m not sure what to do here
What do you have in your builder.yml?
Here’s my builder.yml. I’m only trying to build the kernel here:
git:
baseurl: https://github.com
prefix: QubesOS/qubes-
branch: release4.2
maintainers:
# marmarek
- '0064428F455451B3EBE78A7F063938BA42CFA724'
# simon
- '274E12AB03F2FE293765FC06DA0434BC706E1FCF'
backend-vmm: xen
debug: true
verbose: true
qubes-release: r4.2
distributions:
- host-fc37
- vm-bookworm
- vm-fc39
- vm-fc40
templates:
- fedora-39:
dist: fc39
options:
- selinux
- fedora-40:
dist: fc40
options:
- selinux
- debian-12:
dist: bookworm
options:
- firmware
- whonix-gateway-17:
dist: bookworm
flavor: whonix-gateway
options:
- minimal
- no-recommends
- whonix-workstation-17:
dist: bookworm
flavor: whonix-workstation
options:
- minimal
- no-recommends
components:
- builder-rpm:
packages: False
branch: main
- linux-kernel-latest:
url: https://github.com/QubesOS/qubes-linux-kernel
branch: main
timeout: 21600
#executor:
# type: docker
# options:
# image: "qubes-builder-fedora:latest"
executor:
type: qubes
options:
dispvm: "@dispvm"
stages:
- fetch
- prep
- build
- post
- verify
- sign:
executor:
type: local
- publish:
executor:
type: local
- upload:
executor:
type: local
What template do you use for work-qubesos and qubes-builder-dvm?
I’ve tried it with fedora-40-xfce template and I didn’t have this error with your config.
Fixed! I was using fedora-39 and using fedora-40-xfce fixed it. Thank you so much!
However, I seem to be getting a new error when prepping:
00:36:11 [qb] An error occurred: linux-kernel-latest:host-fedora-37.x86_64:kernel.spec: Failed to get source information: Failed to run '/usr/bin/qvm-run-vm -- disp7378 env -- VERBOSE=1 DEBUG=1 BACKEND_VMM=xen DIST=fc37 PACKAGE_SET=host bash -c '/builder/plugins/source_rpm/scripts/get-source-info /builder/linux-kernel-latest /builder/linux-kernel-latest/kernel.spec fc37'' (status=1)..
00:36:11 [qb]
File "/home/user/qubes-builderv2/qubesbuilder/plugins/source_rpm/__init__.py", line 173, in run
executor.run(
File "/home/user/qubes-builderv2/qubesbuilder/executors/qubes.py", line 377, in run
raise e
File "/home/user/qubes-builderv2/qubesbuilder/executors/qubes.py", line 346, in run
raise ExecutorError(msg, name=dispvm)
qubesbuilder.executors.ExecutorError: Failed to run '/usr/bin/qvm-run-vm -- disp7378 env -- VERBOSE=1 DEBUG=1 BACKEND_VMM=xen DIST=fc37 PACKAGE_SET=host bash -c '/builder/plugins/source_rpm/scripts/get-source-info /builder/linux-kernel-latest /builder/linux-kernel-latest/kernel.spec fc37'' (status=1).
The above exception was the direct cause of the following exception:
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_base.py", line 76, in __call__
rv = self.main(*args, standalone_mode=False, **kwargs)
File "/usr/lib/python3.12/site-packages/click/core.py", line 1078, in main
rv = self.invoke(ctx)
File "/usr/lib/python3.12/site-packages/click/core.py", line 1688, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/lib/python3.12/site-packages/click/core.py", line 1719, in invoke
rv.append(sub_ctx.command.invoke(sub_ctx))
File "/usr/lib/python3.12/site-packages/click/core.py", line 1434, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/lib/python3.12/site-packages/click/core.py", line 783, in invoke
return __callback(*args, **kwargs)
File "/usr/lib/python3.12/site-packages/click/decorators.py", line 45, in new_func
return f(get_current_context().obj, *args, **kwargs)
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_package.py", line 75, in prep
_component_stage(
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_package.py", line 41, in _component_stage
p.run(stage=stage_name)
File "/home/user/qubes-builderv2/qubesbuilder/plugins/source_rpm/__init__.py", line 178, in run
raise SourceError(msg) from e
qubesbuilder.plugins.source.SourceError: linux-kernel-latest:host-fedora-37.x86_64:kernel.spec: Failed to get source information: Failed to run '/usr/bin/qvm-run-vm -- disp7378 env -- VERBOSE=1 DEBUG=1 BACKEND_VMM=xen DIST=fc37 PACKAGE_SET=host bash -c '/builder/plugins/source_rpm/scripts/get-source-info /builder/linux-kernel-latest /builder/linux-kernel-latest/kernel.spec fc37'' (status=1)..
I don’t have this error when I run ./qb package prep after ./qb package fetch finished successfully.
Did you change the template for both work-qubesos and qubes-builder-dvm to fedora-40-xfce?
Did you install dependencies for both work-qubesos and qubes-builder-dvm in fedora-40-xfce?
Works now, I had to reinstall dependencies
