Thanks to everyone who contributed to printer documentation for Qubes - I’ve learned a lot, but still stumped by this issue.
I’m running Qubes R4.2.1 on a Nitrokey nitropad-nv41 laptop.
Kernal: 6.1.75-1
CUPS: 2.4.7
I successfully set up a fedora-39-xfce template VM with my Epson ET-3750 network printer after many hours of trial and error and bashing my head against the wall. I was able to print the test page and documents without issue. I declared success and celebrated by going to sleep. The next day I tried to re-create another template to make sure I had the process down before I set up a disposable VM based on the template. I’m stuck because I can’t recreate a template that successfully pairs with the printer. This is my installation approach - please let me know if you see any corrections I can make.
- Clone the fedora-39-xfce template to create a new template VM (let’s call it NewT)
- Open NewT settings to set the Net qube to sys-firewall - Apply to assign IP address
- From NewT command line, install my software (sudo dnf install yum, pdfarranger, vi cups)
- From NewT command line, install OnlyOffice using yum
- From NewT Firefox instance, download Epson linux drivers from the Epson website
- Shutdown NewT qube
- From dom0 command line, enable cups (qvm-service --enable fedora-39-xfce-clone-5 cups)
- Restart NewT - verify in Settings >> Services tab that cups is enabled
- From NewT command line, install drivers (sudo rpm -i EpsonDrivers.rpm)
- From NewT File Manager, open and extract the ppd for my printer - store it in Documents
- From NewT command line, open printer settings GUI (sudo system-config-printer)
- Add printer → Device URI (from printer): http://192.168.50.26:631/ipp/print/
- At prompt, point to the specific, unzipped .ppd file for my printer
- Print test page
And that’s when I get the error message for Printer State: “Stopped - The printer configuration is incorrect or the printer no longer exists.” When I go to the Policies group of the Printer Settings GUI, the Enabled checkbox is unchecked (it is checked in the template that successfully prints). When I try to check the box, it reverts quickly to being unchecked.
I know the printer exists because I can use it flawlessly from my other template that I was able to magically connect (let’s call it GoodT). I’ve reviewed CLI history for GoodT and tried to duplicate it - no luck. I thought GoodT might be blocking some other templates somehow, so I backed it up and then deleted it from my system… that didn’t do anything either. I’ve also edited the /etc/cups/cupsd.conf file in NewT to look like GoodT - it doesn’t do anything.
Thank you for any suggestions.
