Correction…I can now copy from dom0 to domains
qvm-copy-to-vm <target_vm>
That’s because of the spaces in the filenames, you need to escape them with \
qvm-run -p HardDrives_USBs 'cat /home/user/Bliss\ v11.14_5.10.32k.iso' > Bliss\ v11.14_5.10.32k.iso
Notice the name: Bliss\ v11.14_5.10.32k.iso
But as it was pointed out, this doesn’t make incredible sense since you can run an HVM from an iso located in a vm.
If you want to it from GUI, create a new Standalone VM with template set to None, then open the advanced settings, select “Boot qube from CD-ROM”, select “from file in qube” and the path.
@BEBF738VD Thank you very much. I see now and all is well and working, Thank you all for your time…
No worries. Please select an answer so we can close this.
Ok, just did…
Thanks for everything
