OK, so I am trying to copy over my iso to dom0 in terminal in dom0 to build out. With
"qvm-run -p where downloaded 'cat /from domain
I keep geting file not found but I am looking rigth at it in my domain where I downloaded it too.
So I then do the hole
Qubes tools>Create Qubes vm (the hole process) change memory size, hard drive sizes.
Attach iso via Qubes settings
The iso launches I get to where I can install the iso BUT then once initiated I get from the installer… NO Hard drive found…
Now i am taking screen shots from dom0 so I can show you all these stuff…
Well after my screenshots I need to copy over to my domain so I can upload here BUT when I run in terminal in dom0…
qvm-copy-to-vm vm screenshot
Here I will type what I get…
I need to copy it over to dom0 so I can install iso
qvm-run -p VM ‘cat /home/user/ isoname’ > isoname
Gives me this error
Traceback (most recent call last)
File “/usr/bin/qubes-vmexec”, line 5, in
sys.exit(main())
File “/usr/lib/python3.10/site-packages/qubesagent/vmexec.py”, line 55, in main
os.execvp (command [0], command)
File “/usr/lib64/python3.10/os.py”, line 575, in execvp
execvpe (file, args)
File “/usr/lib64/python3.10/os.py”, line 598, in _execvpe
exec_func (file, *argest)
FileNotFoundError: [Errno 2] NO such file or directory
I can see it in my domain even the iso size.
@mila Yes, I know this but I want to install it so that I don’t have to keep launching the domain it is downloaded to. I can run it fully from iso. When I type to install it from the installer inside the iso even after I have the hvm setup, you know (memory,hard drive size increased…all of that) The iso install is not seeing the Hard drive as it will kick back " no hard drive to partition or setup"
@BEBF738VD No, this is the latest “Android” Bliss v11.14 with kernal 5.10.32
I had Android Bliss v11.13 kernal 4.19.xx (don’t remember install) and deleted it yesterday after I donwloaded and verified tis one. So I know it’s legit. I just can’t move to dom0 or install it anyway I try…
Last metadata expiration check: 3:49:06 ago on Sat NOv 19 11:47:11 2022
Package zenity-3.42.1-1.fc36.x86_64 is already installed
Dependencies resolved
Nothing to do
Complete
I can not copy from dom0 to domains or from domains to dom0
I still get that error when running
qvm-run -p Storage ‘cat /home/user/xxx.iso’ > xxx.iso
sys.exit(main())
