Before what I did, I could click on the devices icon in the system tray, select my secondary hard disk, attach it to one of my VM and inside that VM I could see a new hard disk appear in the file manager.
After formating that disk by running: sudo mkfs -t ntfs /dev/xvdi
I can no longer do what I did above. Now, when I attach the same disk to VM, I can’t see him in the file manager. I do able to see him by running the lsblk inside the VM.
I tried to run: sudo mkdir -p /mt/xvdi sudo mount -t auto /dev/xvdi /mt/xvdi
but it didn’t help. I’m afraid to run qvm-block… not sure if that’s the right thing.
What do I need to do so it will be as it was before?
When I first run what you just said, it showed me that there’s no file or directory. But then I tried to mount again as I did before and then it did showed me my disk, but I can’t see him in the file manager.
How can I make so it will appear as before, next to my file system in the sidebar and not mounting it to /mt/xvdi? Do I leave that mountpoint empty or something else maybe?
It seems to only work for ext filesystem. Or at least it doesn’t work for vfat filesystem and I guess not for ntfs as well.
Maybe the fat/ntfs support could be somehow enabled but I don’t know how.
I don’t think it’s Qubes-specific issue so you can search for this issue with a general Linux systems.
It seems to work using GVFS.
