Can’t enter in password. Tried pressing esc key. Plz help
How do I fix this. I can’t click on the box and whenever I type it doesn’t show up.
You are probably using a USB keyboard going through a USB qube. If you have a ps/2 keyboard you can try connecting that.
It on my laptop so I don’t know. What is an example of these types of keyboards that you are talking about
this topic is more fit to user support category
I put one in their and I got no response.
so why not try bumping? (ie post a reply giving more information)
merged subsequent posts into this thread.
AFAIK you have a possibility to move it yourself as a “Regular”.
when you boot up laptop and in grub menu press e to edit kernel option then
- Find the line that begins with
GRUB_CMDLINE_LINUX. - delete
rd.qubes.hide_all_usb.
press f10 to contiue boot up with this settings.
after that, carefully read this page USB qubes | Qubes OS
