HELPME
December 7, 2022, 10:39am
1
Would a built in SIM card slot, need to be enabled in sys-net or sys-usb?
I don’t know how.its integrated but I would assume PCI. However it could.be usb. It’s built into the back of the laptop.
Also, identifying it in the “devices” tab is difficult. Are there any commands I can run to try help identify it?,
enmus
December 7, 2022, 8:39pm
2
Hello and welcome.
The answer should be easy. If it’s PCI then leave it to dom0, If it’s on an USB controller, then pass it to sys-usb.
Simple lspci in dom0 terminal should help you (us) to be more precise.
HELPME
December 9, 2022, 12:27pm
3
So I have a realtek NIC already on sys-usb but no connection. Do I attach this to sys-net or sys-firewall to get a connection?
mila
December 9, 2022, 1:52pm
4
Hi there,
have You yet checked this post?
In some cases you maybe need combine sys-usb with sys-net. But it’s less secure than having sys-net and sys-usb separate, so be aware of it before doing it. To do it :
In the following file :
nano /etc/qubes-rpc/policy/qubes.InputKeyboard
nano /etc/qubes-rpc/policy/qubes.InputMouse
replace from
sys-usb dom0 allow,user=root
to
sys-net dom0 allow,user=root
Shutdown
Go in the sys-net terminal and shut it down, for exemple with init 0
Go in the sys-usb terminal and shut it down, for exem…
Cheers,
M.
Alternatively, you can proxy the specific device from sys-usb to sys-net using the “Qubes Devices” menu (the one with the usb drive icon). That way you won’t expose all usb controllers to the net.
enmus
December 9, 2022, 3:35pm
6
You have to be specific about your topic subject, and to try to answer/respond on all questions/tips
