The Whonix templates are easily downloaded and installed by following the procedure here. However, they are integrated into qubes-builder so they are straight-forward to build yourself if you prefer.
Many other Qubes templates can also be built by following this procedure. Simply choose the appropriate builder(s) and template(s) you wish to build in the ./setup procedure below. Always include the mgmt-salt builder.
First, set up the Build Environment (follow the build environment section only).
Next, configure the builder:
cd ~/qubes-builder
./setup
# Select Yes to add Qubes Master Signing Key
# Select Yes to add Qubes OS Signing Key
# Select 4.0 for version
# Stable
# Select Current (if you want the option to use pre-built packages)
# Yes (we want to build only templates)
# Select fc29 and stretch (for the currently shipping templates)
# Select builder-rpm, builder-debian, template-whonix, mgmt-salt
# Yes (to download)
Once it completes downloading, re-run setup to add the Whonix templates:
./setup
# Choose the same options as above, except at templates select:
# whonix-gateway-14, whonix-workstation-14
# If prompted, choose Yes to add adrelanos's third party key
Continue the build process with:
make install-deps
make get-sources
You will often need to edit/update qubes-src/template-whonix/builder.conf at this stage to specify the currently shipping Tor Browser version. Open it in your favorite editor, then look for “Extra Whonix Build Options” and add/edit the WHONIX_TBB_VERSION variable to specify the current version. For example:
# Extra Whonix Build Options
# Whonix repository.
WHONIX_APT_REPOSITORY_OPTS ?= stable
#WHONIX_APT_REPOSITORY_OPTS = off
# Use turbo mode to build template
BUILDER_TURBO_MODE ?= 1
# Enable Tor by default (0: disable; 1: enable)
WHONIX_ENABLE_TOR ?= 0
WHONIX_TBB_VERSION ?= 7.5.2
You can add/edit the WHONIX_TBB_VERSION variable in ~/qubes-builder/builder.conf instead of this file if preferred.
Finally, use:
make qubes-vm
make template
Once the build is complete, the install packages for your newly built templates will be located in ~/qubes-builder/qubes-src/linux-template-builder/rpm/noarch. Copy them from there to dom0 and install:
qvm-run --pass-io <src-vm> 'cat ~/qubes-builder/qubes-src/linux-template-builder/rpm/noarch/qubes-template-whonix-gw-4.0.0-201802250036.noarch.rpm' > ~/qubes-template-whonix-gw-4.0.0-201802250036.noarch.rpm
qvm-run --pass-io <src-vm> 'cat ~/qubes-builder/qubes-src/linux-template-builder/rpm/noarch/qubes-template-whonix-ws-4.0.0-201802250145.noarch.rpm' > ~/qubes-template-whonix-ws-4.0.0-201802250145.noarch.rpm
sudo dnf install qubes-template-whonix-gw-4.0.0-201802250036.noarch.rpm
sudo dnf install qubes-template-whonix-ws-4.0.0-201802250145.noarch.rpm
And you are done!
- Page archive
- First commit: 08 Dec 2020. Last commit: 08 Dec 2020.
- Applicable Qubes OS releases based on commit dates and supported releases: 4.0
- Original author(s) (GitHub usernames):
- Original author(s) (forum usernames):
- Document license: CC BY 4.0
