Hmm, I’m giving qubes-builderv2 a try now but it doesn’t seem to have 4.1 in the example-configs only 4.2 (which i don’t think is officially released yet?).
Currently stuck on getting this permission denied on a docker executor build attempt following the instructions in the git readme. SELinux is disabled btw.
[user@qubes-builderv2 qubes-builderv2]$ uname -a
Linux qubes-builderv2 6.1.11-100.fc36.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Feb 9 20:36:30 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
[user@qubes-builderv2 qubes-builderv2]$ ./qb package fetch prep build
Running stage: fetch
Error: [Errno 13] Permission denied: 'qrexec-client-vm'
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_base.py", line 65, in __call__
return self.main(*args, **kwargs)
File "/home/user/.local/lib/python3.10/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/user/.local/lib/python3.10/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/user/.local/lib/python3.10/site-packages/click/core.py", line 1688, in invoke
rv.append(sub_ctx.command.invoke(sub_ctx))
File "/home/user/.local/lib/python3.10/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/user/.local/lib/python3.10/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/home/user/.local/lib/python3.10/site-packages/click/decorators.py", line 38, in new_func
return f(get_current_context().obj, *args, **kwargs)
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_package.py", line 58, in fetch
_component_stage(
File "/home/user/qubes-builderv2/qubesbuilder/cli/cli_package.py", line 39, in _component_stage
p.run(stage=stage_name)
File "/home/user/qubes-builderv2/qubesbuilder/plugins/fetch/__init__.py", line 149, in run
executor.run(cmd, copy_in, copy_out, environment=self.environment)
File "/home/user/qubes-builderv2/qubesbuilder/executors/qubes.py", line 131, in run
result = subprocess.run(
File "/usr/lib64/python3.10/subprocess.py", line 503, in run
with Popen(*popenargs, **kwargs) as process:
File "/usr/lib64/python3.10/subprocess.py", line 971, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/usr/lib64/python3.10/subprocess.py", line 1847, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
PermissionError: [Errno 13] Permission denied: 'qrexec-client-vm'
