Steps.
Clean AppVM based on Fedora 36 template.
git clone https://github.com/QubesOS/qubes-builder.git qubes-builder
cd qubes-builder
Created a builder.conf
make get-sources
make install-deps
make remount
make iso
Build fails with an apparent circular dependency issue with anaconda:
/home/user/qubes-src/installer-qubes-os/work/1337/x86_64/os /home/user/qubes-src/installer-qubes-os
2023-02-09 22:49:08,488: selinux is Disabled
2023-02-09 22:49:08,492: Using platform:f32 for module_platform_id
2023-02-09 22:49:39,438: selinux is Disabled
selinux is Disabled
2023-02-09 22:49:39,438: checking for root privileges
2023-02-09 22:49:39,438: checking dnf base object
2023-02-09 22:49:41,852: setting up build architecture
2023-02-09 22:49:41,853: setting up build parameters
2023-02-09 22:49:41,853: Using templatedir /usr/share/lorax-qubes
2023-02-09 22:49:41,853: installing runtime packages
2023-02-09 22:49:41,865: running runtime-install.tmpl
2023-02-09 22:49:42,028: installpkg: lohit-gu*-fonts expands to lohit-gujarati-fonts-2.92.4-9.fc32,lohit-gurmukhi-fonts-2.91.2-10.fc32
2023-02-09 22:49:42,098: Checking dependencies
2023-02-09 22:50:22,445: Dependency check failed:
Problem 1: package anaconda-1000:37.12.6-2.fc32.x86_64 requires anaconda-tui = 1000:37.12.6-2.fc32, but none of the providers can be installed
- conflicting requests
- nothing provides python3-simpleline >= 1.9.0-1 needed by anaconda-tui-1000:37.12.6-2.fc32.x86_64
Problem 2: package kdump-anaconda-addon-005-8.20200220git80aab11.fc32.noarch requires anaconda >= 21.33, but none of the providers can be installed
- package anaconda-32.24.7-1.fc32.x86_64 requires anaconda-install-env-deps = 32.24.7-1.fc32, but none of the providers can be installed
- package anaconda-32.24.7-2.fc32.x86_64 requires anaconda-install-env-deps = 32.24.7-2.fc32, but none of the providers can be installed
- package anaconda-1000:32.24.5-6.fc32.x86_64 requires anaconda-install-env-deps = 1000:32.24.5-6.fc32, but none of the providers can be installed
- package anaconda-1000:32.24.5-7.fc32.x86_64 requires anaconda-install-env-deps = 1000:32.24.5-7.fc32, but none of the providers can be installed
- cannot install both anaconda-install-env-deps-1000:37.12.6-2.fc32.x86_64 and anaconda-install-env-deps-32.24.7-1.fc32.x86_64
- cannot install both anaconda-install-env-deps-1000:37.12.6-2.fc32.x86_64 and anaconda-install-env-deps-32.24.7-2.fc32.x86_64
- cannot install both anaconda-install-env-deps-1000:37.12.6-2.fc32.x86_64 and anaconda-install-env-deps-1000:32.24.5-6.fc32.x86_64
- cannot install both anaconda-install-env-deps-1000:37.12.6-2.fc32.x86_64 and anaconda-install-env-deps-1000:32.24.5-7.fc32.x86_64
- package anaconda-1000:37.12.6-2.fc32.x86_64 requires anaconda-tui = 1000:37.12.6-2.fc32, but none of the providers can be installed
2023-02-09 22:50:22,445: template command error in runtime-install.tmpl:
2023-02-09 22:50:22,445: run_pkg_transaction
run_pkg_transaction
2023-02-09 22:50:22,446: dnf.exceptions.DepsolveError:
File "/usr/sbin/lorax", line 223, in <module>
main()
File "/usr/sbin/lorax", line 204, in main
lorax.run(dnfbase, opts.product, opts.version, opts.release,
File "/usr/lib/python3.8/site-packages/pylorax/__init__.py", line 264, in run
rb.install()
File "/usr/lib/python3.8/site-packages/pylorax/treebuilder.py", line 136, in install
self._runner.run("runtime-install.tmpl")
File "/usr/lib/python3.8/site-packages/pylorax/ltmpl.py", line 149, in run
self._run(commands)
File "/usr/lib/python3.8/site-packages/pylorax/ltmpl.py", line 168, in _run
f(*args)
File "/usr/lib/python3.8/site-packages/pylorax/ltmpl.py", line 631, in run_pkg_transaction
self.dbo.resolve()
File "/usr/lib/python3.8/site-packages/dnf/base.py", line 848, in resolve
raise exc
make[1]: *** [Makefile:132: iso-installer-lorax] Error 1
--> build failed!
make: *** [Makefile:575: iso] Error 1
