I am trying to build a new archlinux template ( An built one successfully after some manual modifications), however, I detected a weird issue (that break the template building):
Can confirm.
Status changes and evowise.com is having a hard time atm.
Look at Arch Linux - Mirror Status
Change the mirror list to use mirrors with a mirror score of 0.
Thanks manually modifying the mirrorlist make it work
Found this pacman issue and added a comment: FS#61497 : Add a timestamp file to repos
I believe it is in the scope of pacman to find a good mirror among the one available.
