Have done a search and can’t find instructions on this, qubes-builder by default pulls from a qubes RPM repo which has fc versions 28-32. Does everything (except gcc) need to be built from source?
Would be useful if the answer could be added to here
FC32 was out nearly 3 years ago and those with more modern hardware (or wanting a newer KDE/Plasma) will likely want modern packages/firmware/power management in Dom0.
That’s helpful, but this will be for prod so I can’t be running bleeding edge of the Qubes tools
Whereas FC 37 (or 36) would be nice to get the advantage of better hw support etc.
(should also mention this is a KDE build and I’m doing some stuff in Kickstarter too, so the weeklies aren’t necessarily as useful to me as the recipe to build from packages). Compiling everything from source would be…time consuming.
Thanks for this reply, I’m running kernel-latest but S3 suspend doesn’t work in Qubes 4.1 fc32 but does work on a stock Fedora 37 LiveUSB, haven’t figured out the difference yet so thought it would be simpler to upgrade dom0.
