Build Security - Multi-Sig and Transparency Log Approach
Qubes’ current release signing flow relies on a single point of trust — one person holds the release key. It’s worked for over a decade, but “hasn’t been compromised yet” isn’t the same as “can’t be compromised.”
Everyone agrees deterministic builds + multi-signature is the right direction. Issue #816 has been open for years, which shows the community knows its value. But full determinism is a heavy lift — getting thousands of packages across dozens of upstream projects to produce bit-identical output is a massive undertaking.
This post explores a question: Can we build a multi-signature verification system without waiting for 100% determinism?
Two Problems to Solve
  1. Single point of failure in the build process. If the signing key is stolen or the build server is compromised, a malicious ISO can be signed and distributed without users knowing.
  2. Compiler trust. Ken Thompson (1984) showed that reviewing source code isn’t enough — a compromised compiler can inject backdoors during compilation and then erase its own traces. Your “trusted source” can produce untrusted binaries.
These are different problems, but they can be addressed together.
The Approach: Three Layers
Layer 1: Trust Anchor → 512 Bytes
The Stage0 project provides a bootstrap chain starting from a 512-byte hex monitor, building up to a full C compiler:
hex monitor (512 bytes)
  → Stage0 → hex2 (ELF file generator)
  → M2-Planet (minimal C compiler)
  → tcc (full C compiler, ~100KB)
  → compile gcc with tcc
  → compile Qubes with gcc
512 bytes — about a dozen lines of assembly. You can read it all and understand what it does.
Then use DDC (Diverse Double Compilation): compile the same source with two independent compiler implementations (tcc and gcc). If outputs match → neither compiler is compromised. If they differ → something is wrong, trigger manual review.
DDC doesn’t need to run every release — once a quarter is enough. A compiler backdoor doesn’t self-destruct and doesn’t change every three months.
Layer 2: Seven People Each Build — Outputs Don’t Need to Match
The conventional wisdom is “make everything deterministic first, then add multi-sig.” But full determinism for a project as large as Qubes is a long road — timestamps, filesystem ordering, CPU instruction differences, compiler versions. It’s real work.
Alternative framing: We don’t need determinism. We need consensus.
Seven independent builders (different continents, different organizations) each run the same locked build container and source manifest, then sign their own ISO hash.
The result might look like this:
Builder Output Hash Signed
Alice a1b2c3 :white_check_mark:
Bob a1b2c3 :white_check_mark:
Carol d4e5f6 :white_check_mark:
Dave a1b2c3 :white_check_mark:
Eve a1b2c3 :white_check_mark:
Frank d4e5f6 :white_check_mark:
Grace a1b2c3 :white_check_mark:
a1b2c3 has 5 signatures, d4e5f6 has 2. Threshold = 4 → publish a1b2c3. Carol and Frank get a diffoscope report to find their discrepancy.
You don’t need uniform output. You need majority consensus.
Math: if each builder has a 1% compromise probability, threshold 4/7, the probability of a successful forgery is ~3×10⁻⁸. Several orders of magnitude better than single-signer.
Layer 3: Transparency Log — Public, Append-Only
Signatures need a public, tamper-evident record that anyone can query.
Implementation: Merkle tree + multi-medium publishing. Each log entry:
version | prev_hash | release_id | builder_id | output_hash | Ed25519_sig
The Merkle root (32 bytes) is published regularly to multiple independent channels:
  • DNS TXT record (DNSSEC-signed)
  • Bitcoin OP_RETURN
  • IPFS
  • Fediverse
Tampering with history requires compromising DNS infrastructure, the Bitcoin network, IPFS gateways, and Fediverse accounts simultaneously. The engineering difficulty is high enough to be meaningful.
User workflow: download ISO → compute SHA256 → query transparency log for ≥4 matching signatures → found → install. Not found → file a report.
User Experience
Ideally, one command:
qubes-verify --iso Qubes-4.4.0-x86_64.iso
Behind the scenes:
  1. Compute ISO SHA256
  2. Query transparency log for matching signatures
  3. Verify each signature’s validity
  4. Check signature count ≥ threshold
  5. Verify Merkle root against DNS/blockchain records
  6. All pass → green :white_check_mark:
The log is public. Anyone can run a monitor bot. If something’s wrong, the whole community knows.
Implementation Path
Four phases, each producing independently useful output:
Phase 0 (3-6 months): Infrastructure
  • Containerize the build environment with locked versions
  • Standardize the build manifest format
  • Deploy transparency log server
No changes to existing build workflow — just adding a recording and verification layer around it.
Phase 1 (3-6 months): Protocol
  • Build verification distribution and signature collection
  • User-facing verification tool
  • Log monitor bot
Phase 2 (timeline depends on community): Verification Farm
  • Recruit 5-7 independent signing nodes
  • Open witness nodes for the community (anyone can run verification and submit witness hashes)
  • Run traditional signing and multi-signing in parallel, gradually transition
Phase 3 (ongoing): DDC Bootstrap Chain
  • Port Stage0 → tcc → gcc bootstrap chain
  • Run quarterly cross-compilation verification
  • Results public, community oversight
Relationship to Existing Work
Marek and the team have done solid work on qubes-builder: sandboxed builds, Tor routing, source signature verification. Containerized build environments are a natural extension of this work, not a replacement.
This proposal isn’t about discarding the determinism goal. It’s about not waiting for full determinism before adding multi-sig verification. Both efforts can proceed in parallel, and the transparency log + multi-sig infrastructure is valuable even before determinism is complete.
Caveats
  • Does not protect against targeted attacks. An attacker who bypasses the transparency log and hands you a fake ISO directly can still succeed. This requires user-side multi-channel verification.
  • DDC doesn’t cover CPU microcode or hardware backdoors. That’s an industry-wide problem, not unique to Qubes.
  • Transparency log requires ongoing maintenance. Merkle tree server, multi-medium publishing, monitor bots — all need someone to maintain them.
  • The hardest part might not be technical. Finding 5-7 reliable signing nodes across different organizations requires community participation. That’s an organizational challenge.
Discussion welcome. I can go deeper on the technical details — the organizational side is up to the community.
References
Interesting proposal. One thing I would separate clearly is “majority consensus” vs “verification”: if the same locked manifest or source set is already bad, 4/7 builders can still agree on the wrong artifact. So I think the transparency log is the strongest early win, but the verifier should show exactly which source manifest, builder image hash, and policy threshold were used, not just the ISO hash. That also makes diffoscope reports useful without implying the non-majority builders are compromised.
Or both are compromised the same way?
Yes, exactly. Matching outputs only rule out the easy case where one build path was uniquely compromised or misconfigured. If both builders consume the same poisoned source, same compromised compiler lineage, or same malicious build container, they can match perfectly.
That is why I’d treat multi-sig as a policy/control improvement, not as a proof of clean binaries by itself. The useful checks are diversity and auditability: pinned source manifest, builder image hash, compiler/toolchain provenance, reproducible logs, and a transparency log that lets people notice when the inputs changed unexpectedly.
