Build error - 4.2, failing in qubes-gui-agent
First time building, I’m using builderv2 and I’m many hours into a ./qb package fetch prep build and getting a repeatable failure I can’t see where to go with.
The last non-[executor] log line is:
[build_deb] gui-daemon:vm-debian-11.amd64:debian: Provisioning local repository '/home/user/qubes-builderv2/artifacts/repository/vm-bullseye'.
stderr (not in the log files) gives:
Error: gui-agent-linux:vm-debian-11.amd64:debian: Failed to build packages: Failed to run 'sudo mkdir -p -- /builder /builder/build /builder/plugins /builder/distfiles&&sudo chown -R -- user:user /builder&&sed -i 's#@BUILDER_DIR@#/builder#g' /builder/pbuilder/pbuilderrc&&mkdir -p /builder/cache/aptcache&&/builder/plugins/build_deb/scripts/create-local-repo /builder/repository debian bullseye&&sudo -E pbuilder create --distribution bullseye --configfile /builder/pbuilder/pbuilderrc --othermirror "deb [trusted=yes] file:///tmp/qubes-deb bullseye main"&&sudo -E pbuilder build --override-config --distribution bullseye --configfile /builder/pbuilder/pbuilderrc --othermirror "deb [trusted=yes] file:///tmp/qubes-deb bullseye main" /builder/build/qubes-gui-agent_4.2.14-1+deb11u1.dsc&&/builder/plugins/build_deb/scripts/patch-changes /builder/build/qubes-gui-agent_4.2.14-1+deb11u1.dsc /builder/pbuilder/results/qubes-gui-agent_4.2.14-1+deb11u1_amd64.buildinfo /builder/pbuilder/results/qubes-gui-agent_4.2.14-1+deb11u1_amd64.changes' (status=1)..
Searching the log file for errors, I only see this right at the end:
[executor:docker:3764f8f90a30] output: cc -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2 -ffile-prefix-map=/build/qubes-gui-agent-4.2.14=. -fstack-protector-strong -Wformat -Werror=format-security -D_REENTRANT -I/usr/include/pipewire-0.3 -I/usr/include/spa-0.2 -I/usr/include/vchan-xen -fno-strict-aliasing -fno-strict-overflow -fno-delete-null-pointer-checks -fPIC -Wall -Wextra -Werror -Wno-missing-field-initializers -Wno-unused-parameter -ggdb -O2 -c -o build/qubes-pw-module.o qubes-pw-module.c -MP -MD -MF build/qubes-pw-module.o.dep
[executor:docker:3764f8f90a30] output: qubes-pw-module.c: In function 'trigger_process':
[executor:docker:3764f8f90a30] output: qubes-pw-module.c:533:5: error: implicit declaration of function 'pw_stream_trigger_process' [-Werror=implicit-function-declaration]
[executor:docker:3764f8f90a30] output:   533 |     pw_stream_trigger_process(stream->stream);
[executor:docker:3764f8f90a30] output:       |     ^~~~~~~~~~~~~~~~~~~~~~~~~
[executor:docker:3764f8f90a30] output: qubes-pw-module.c: In function 'rt_set_stream_state':
[executor:docker:3764f8f90a30] output: qubes-pw-module.c:1030:24: error: implicit declaration of function 'pw_stream_is_driving' [-Werror=implicit-function-declaration]
[executor:docker:3764f8f90a30] output:  1030 |         bool driving = pw_stream_is_driving(stream->stream);
[executor:docker:3764f8f90a30] output: qubes-pw-module.c: In function 'stream_param_changed':
[executor:docker:3764f8f90a30] output: qubes-pw-module.c:1337:10: error: 'SPA_PARAM_Latency' undeclared (first use in this function); did you mean 'SPA_IO_Latency'?
[executor:docker:3764f8f90a30] output:  1337 |     case SPA_PARAM_Latency:
[executor:docker:3764f8f90a30] output:       |          SPA_IO_Latency
[executor:docker:3764f8f90a30] output: qubes-pw-module.c:1337:10: note: each undeclared identifier is reported only once for each function it appears in
[executor:docker:3764f8f90a30] output: qubes-pw-module.c: In function 'pipewire__module_init':
[executor:docker:3764f8f90a30] output: qubes-pw-module.c:1592:35: error: implicit declaration of function 'pw_context_get_work_queue'; did you mean 'pw_context_get_object'? [-Werror=implicit-function-declaration]
[executor:docker:3764f8f90a30] output:  1592 |     struct pw_work_queue *queue = pw_context_get_work_queue(context);
[executor:docker:3764f8f90a30] output:       |                                   pw_context_get_object
[executor:docker:3764f8f90a30] output: qubes-pw-module.c:1592:35: error: initialization of 'struct pw_work_queue *' from 'int' makes pointer from integer without a cast [-Werror=int-conversion]
[executor:docker:3764f8f90a30] output: cc1: all warnings being treated as errors
[executor:docker:3764f8f90a30] output: make[3]: *** [Makefile:19: build/qubes-pw-module.o] Error 1
[executor:docker:3764f8f90a30] output: make[3]: Leaving directory '/build/qubes-gui-agent-4.2.14/pipewire'
[executor:docker:3764f8f90a30] output: make[2]: *** [Makefile:81: pipewire/qubes-pw-module.so] Error 2
[executor:docker:3764f8f90a30] output: make[1]: *** [debian/rules:21: override_dh_auto_build] Error 2
I didn’t see anything in the issue tracker that looked related. There’s a change to the first file mentioned from a week ago. I’m not familiar with it but I can’t see how that would be the cause. I could try pinning the version of that module if anyone can tell me how.
Environment: fedora-40-xfce, builderv2 tag mm_3b31004e (4 commits behind current main), copied example-configs/qubes-os-r4.2.yml to builder.yml and edited to use the docker executor built with ./tools/generate-container-image.sh docker fedora-40-x86_64.
I’m minded just to start fresh with fedora-38-xfce, but as it’s taken something like 10 hours to get here and re-running from this point only takes 90 mins I thought I’d ask here first.
Maybe debian 11 template building is not supported anymore? Or at least pipewire part.
I’d remove debian 11 from builder.yml and try again.
Yes, that’s it: Supported releases | Qubes OS
I’ve just pushed update to the example config to fix this.
Thank you, do I need to rebuild from scratch?
