Hello community! Thank you all in advance who take your time to read, comment & trying to be helpful to me & all the community members, I do appreciate it a lot, THANK YOU ![]()
This bug popin up each 10-40 min while I am online, it also decrease my onion circuits till I have zero circuits. To get back online I do “Restart Tor” (at the sys-whonix control panel) or “Restart sdwdate”, sometimes even both, restart tor & sdwdate.
(why do I restart sdwdate? -because it gives me a new onion-circuits similar to “New Identity” button. “New Identity” button lagging so so bad! it is much easier to restart sdwdate than wait & hope for a few minutes or more till OS will give me new identity credentials)
Questions:
- How to fix this issue or when Developers will fix this problem?
- How dangerous this issue?
How this issue/bugs effect my privacy & anonymity? - Something else should I be caution about?
[sys-whonix] tor-control-panel
Bugs related to Tor logs:
**[warn] tor_bug_occurred_(): Bug: ../src/core/or/conflux_util.h:31: CIRCUIT_IS_CONFLUX: Non-fatal assertion circ->purpose != CIRCUIT_PURPOSE_CONFLUX_LINKED failed. (on Tor 0.4.8.15 )**
**[warn] Bug: Tor 0.4.8.15: Non-fatal assertion circ->purpose != CIRCUIT_PURPOSE_CONFLUX_LINKED failed in CIRCUIT_IS_CONFLUX at ../src/core/or/conflux_util.h:31. Stack trace: (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(log_backtrace_impl+0x57) [0x64d84bf111d7] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(tor_bug_occurred_+0x169) [0x64d84bf1c139] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(circuit_describe_status_for_controller+0x483) [0x64d84bfe2b93] (on Tor 0.4.8.15 )*
**[warn] Bug: /usr/bin/tor(control_event_circuit_status+0xbd) [0x64d84bfded0d] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(circuit_close_all_marked+0x17d) [0x64d84bf8a43d] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(+0x70349) [0x64d84be96349] (on Tor 0.4.8.15 )**
**[warn] Bug: /lib/x86_64-linux-gnu/libevent-2.1.so.7(+0x21482) [0x7f009f549482] (on Tor 0.4.8.15 )**
**[warn] Bug: /lib/x86_64-linux-gnu/libevent-2.1.so.7(event_base_loop+0x49f) [0x7f009f549c1f] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(do_main_loop+0xf1) [0x64d84be976c1] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(tor_run_main+0x1e5) [0x64d84be92ff5] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(tor_main+0x59) [0x64d84be8f329] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(main+0x19) [0x64d84be8eee9] (on Tor 0.4.8.15 )**
**[warn] Bug: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7f009ec4624a] (on Tor 0.4.8.15 )**
**[warn] Bug: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f009ec46305] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(_start+0x21) [0x64d84be8ef31] (on Tor 0.4.8.15 )**
**[warn] Bug: /usr/bin/tor(circuit_describe_status_for_controller+0x483) [0x64d84bfe2b93] (on Tor 0.4.8.15 )**
ps. original text was all highlighted with yellow color, if it’s matter.
