Summary:
During the boot process of Qubes OS, certain jobs (e.g., qubes-vm@... services) hang for over 5 hours without completing. After restarting, the system functions correctly, and no errors appear in journalctl logs. Attempts to mitigate the issue by setting a time limit for jobs to start have not resolved the problem. CPU and hardware activity appear normal during the hang, with no excessive heat or fan noise.
Steps to Reproduce
- Boot the system normally.
- Observe jobs like
qubes-vm@sys-firewall,qubes-vm@sys-usb, and others starting during the boot process. - Wait for the system to finish starting up.
- Experience hangs where some jobs take over 5 hours to complete.
Expected Behavior
All system jobs complete within a reasonable time during the boot process.
Observed Behavior
- Specific jobs remain in the “starting” state for hours (e.g.,
qubes-vm@...jobs). - After a manual restart, the system boots successfully, and all services work as expected.
- Logs (
journalctl -b) show no apparent errors or issues.
Troubleshooting Steps Taken
Checked Logs:
- No errors or warnings found in
journalctl -b. - All jobs appear to have completed successfully after a restart.
Set Job Timeout:
- Modified
/etc/systemd/system.conf:DefaultTimeoutStartSec=120s JobTimeoutSec=120s - Result: Jobs still hang indefinitely during boot.
- Modified
Monitored Hardware:
- No significant CPU or memory usage observed.
- Fans remain inactive, suggesting no unusual workload.
Disabled Autostart VMs:
- Disabled VM autostart (
qvm-prefs <VM_NAME> autostart false) for problematic qubes. - Result: Reduced the number of jobs but did not eliminate the hanging behavior.
Additional Notes
- Hardware Behavior: Normal, with no signs of overheating or high resource usage.
- Workarounds:
- Restarting the system resolves the issue temporarily.
- Disabling VM autostart reduces the number of hanging jobs but does not prevent them entirely.
Conclusion
This issue may be related to:
- A bug in the
systemdjob handling for Qubes OS. - A race condition or dependency issue between
qubes-vm@...services. - Hardware-related quirks that are not reported in logs.
