Install qubes 4.0.4. Use custom partitioning → use btrfs and let the installer partition the SSD automatically. Reboot and login to the new installation of Qubes OS.
Edit /etc/fstab and set mount option of the btrfs partition as subvol=root,xsystemd.device-timeout=0,noatime,compress,autodefrag. Reboot.
dnf remove qubes-template-fedora-33-minimal gives this error:
qvm-template-postprocess:
error: No Qube with this name exists
Error in PREUN scriptlet in rpm package qubes-template-fedora-33-minimal
qubes-template-fedora-33-minimal-....
noarch was supposed to be removed but is not!
Verifying ...
Removed:
qubes-template--fedora-33-minimal...
Complete!
