Hi guys,
I’ve been trying to get into Qubes for about 4 years now
Last time I manage to get it working I saw that in any browser, when opening a new tab, Qubes opens a new window … which is very problematic as I work with 3 browsers, about 5 windows each, and about 10 to 30 tabs each.
No, I don’t need 100% at all times, but at least half of it
The discussion at the time went like: It won’t change, it’s a matter of security !
But I’m still not convinced about any security advantage to not allow multi-tabs in a single browser window (If I need to separate two tabs, then I will choose to open it in a new window)
I’m about to give a new (4.2.RC1) try but before that, I’d like to know if this problem has been solved (Qubes allowing multi-tabs) or still a no-go ? (then I will need to boot to another OS to be able to work, and come back to Qubes for … not working.
My partitioning and configuration will depend on that.
Thks !
What browser are you using?
I’ve been using Firefox on Qubes for years and have never seen this behavior.
Seconded.
I’ve also checked with my network and no one reports ever seeing this behaviour.
@Erica.vH - it looks as if you should be good to go with giving 4.2.1 a try.
It was Firefox
Now I’m using Brave, FF, Tor, Librewolf, …
Yes, as seen in a parallel pôst, all data (from this forum) about this subject are gones ,
It was FF and I wasn’t the only one, but a minority
So yu ae saying that now tabs opens inthe same window ? Good !!
Thank you all ![]()
