Brightness problem in v4.3
Hello
To all, i have the v4.3 and is not have the well brightness adjustment as easy to access in the taskbar on Xfce. I am doing at the keyboard is not responding well in StarBook Horizon.
Try clicking the battery icon on the desktop, then choose Settings, select ‘handle display brightness keys’, then adjust the number to the appropriate value.
I noticed that why when i pressing on keyboard is no working well?
I think the number 12 is appropriate. Honestly, I don’t know why it reaches a certain percentage and then the screen turns off completely.
I able to fix the problem of the Brightness QubesOS Xfce.
  1. Go to the Battery Icon, then see the parts of Display Brightness then click the part of the Setting.
  2. Power Manager; go the part of Brightness Step Count; then increasing the numbers as 100.
  3. That is all.
