So basically I wanted to add my SD card to the sys-usb qube to backup some qubes before doing a clean install. As I didn’t know which device was the SD card I stupidly added a lot of devices to the sys-usb qube and then Qubes just crashed.
Now I can only reach the password screen. If I insert the password it crashes again!
So I would just need to make Qubes don’t start the sys-usb qube automatically.
Qubes is… rather intolerant of that sort of thing, as you’ve now learned!
What are you trying to do, and what isn’t working to access grub?
Power your system on, and start pressing up/down/up/down… This will provide a key input to Grub, letting you then edit the command line as per the documentation you linked.
@QNewbie Generally, USB storage devices are not mounted into the sys-usb qube which is a service qube. Instead, just the useful block partitions are mounted into a regular app qube.
