Brainstorm & Survey: Qubes OS Workstation Setup for Sysadmin
Hey everyone,
I’m currently working on my bachelor’s thesis, which involves creating a Qubes OS-based workstation for system administrators. The goal is to leverage Qubes OS to build a secure yet practical environment for daily admin tasks. I’d love to gather your thoughts and brainstorm together. Here are some initial ideas and questions:
  1. Domain / VM Structure in Qubes OS
  • How would you organize and split up the domains or VMs?
  • Would you create a separate VM with internal access to the company network?
  • Would you keep management consoles in their own dedicated VM to isolate critical admin tasks?
  • Or would you prefer multiple smaller VMs, each for a specific task (like monitoring, configuration, user management, etc.)?
  1. Daily Workflow & Tooling
  • Which tools and software would you run in which domain/VM?
  • Do you see any value in having dedicated Disposable VMs for riskier tasks (like testing unfamiliar software, fetching updates, etc.)?
  • How would you transfer files or logs between domains? Any best practices to avoid cross-contamination?
  • What are the must-have admin tools in your daily routine?
  1. Security vs. Usability
  • Which security measures are absolutely essential?
  • Where might you make trade-offs for a more user-friendly experience, even if it slightly increases risk?
  • How do you ensure that daily tasks don’t become too cumbersome (e.g., constantly switching domains or copying files)?
  1. Additional Considerations
  • How do you feel about network segmentation within Qubes (e.g., a dedicated firewall VM)?
  • Any experience with automated patch management in a Qubes environment?
  • What should we keep in mind for scalability (e.g., when there’s a larger admin team or broader responsibilities)?
  • Any best practices you’d recommend when working with Qubes OS?
I really appreciate any insights, tips, or experiences you might share—everything helps me refine my project. Thank you in advance for your feedback!
Best regards,
Hi
I do sysadmin for clients and myself, here are how I proceed:
For each client, I have
  • a sys-vpn qube as they all require a VPN
  • a sys-vpn-firewall because you need a safe netvm between qubes and the sys-vpn for holding the firewall rules
  • a ssh qube
  • a vault qube
  • desktop stuff qube (conferencing, emails)
I only allow clipboard to work between the qube of a given clients, so I can’t inject crap or exfiltrate data accidently.
This highly depend the trust I have in source material, I rarely use disposable except if I need to try something weird that could damage the user profile in a qube.
Tools I use are usually those:
  • firefox or chromium depending what I need
  • keepassxc for the vault and ssh agent
  • nix, terraform, git, toolschains (nodejs, rust, gcc, go), pip, npm, whatever I need for a task
  • gimp to handle pictures
I always ensure the vpn firewall does not allow to bypass the VPN, so I’m quite sure I won’t leak client data outside the VPN.
I make sure the clipboard is limited, and that the backup policy matches the one at my client, most of the time I do not backup my clients qubes by default, I just do a backup into the qube itself to send it to my client’s storage, otherwise it could be considered as data exfiltration.
I don’t split the tasks into more qubes, I need to be productive and the security level reached is already far superior to what most of my clients would hope for themselves.
As usability tradeoff, I never reboot qubes after a template update as I shutdown my computer every day, this is way less disruptive.
I guess I already replied to most points here :smiley:
Is it OK if I’ll ask questions directly here regarding what you said or should I open a new topic?
This means the structure is:
sys-net, then sys-vpn, then sys-vpn-firewall, correct?
Is this something else than Split SSH?
Can you refer me to the correct method of doing this please?
I’m guessing you do that with the policies, but I have no idea how to make such thing. Is there a guide for this or how do you do that?
Are you using the firewall of the sys-vpn qube itself or where? And what rules do you use for this?
You mean like going to sleep or is it there some security into it? I never shutdown my machine
you forgot sys-firewall :slight_smile:
qubes-clientN-* → sys-client-vpn-firewall → sys-client-vpn → sys-firewall → sys-net
it is simply a dedicated qube to connect to remote hosts using SSH, and it’s using split ssh for the key as I store it in the Vault of that client.
There is a dedicated tab in “Qubes global manager” GUI program. I need to check how to do the same using tags and write the policy myself, but the GUI works fine although it takes 5 minutes to configure a new client.
I use qvm-firewall to add rules for the client VPN, rules are applied on that qube’s netvm which is sys-firewall in this case. The rule is just deny everything except the host and port required to establish the VPN.
yes when I finish my day, I just shutdown the computer.
Hi ! I’m interested by the discussion and I would like to inquire some more information about your network setup.
Why the client-vpn-firewall ? Wouldn’t setting a firewall rule for the client-vpn be enough ? As rules are enforced in the sys-firewall Qube (or am I remembering things wrong?).
ex:
qube-client → sys-client-vpn → sys-firewall (drop any packet from sys-client-vpn that try to connect elsewhere) → sys-net
Thanks :slight_smile:
Firewall rules of a qube are done on that qube’s netvm. As sys-vpn is on the network border (like sys-net) due to the VPN, you should not really trust it to hold firewall rules for the qubes below. That’s why you need a sane firewall qube between a vpn qube and AppVMs below.
Oooh because you restrict your qube-client from connecting to everything !
I think I know why I’m not used to that : the vpn provided wouldn’t allow connection outside of their local/private network.
Thanks for the clarification !
Some VPNs I have to connect to are only used to connect to a range, some are there to pass all traffic toward the Internet, this depends the use case.
But there are cases in which I may want a qube to only connect to SSH hosts for instance.
