Boot qube from DISC or block device doesn't work (USB sticks)
Hi. If I try to boot an HVM from a USB stick the system doesn’t respond. The qube settings just close and there is also no error message. Booting from ISO files works however I tested it with TempleOS but after the install the vm doesn’t boot and is stuck at “Booting from Hard Disk…” so the OS never loads. I think the TempleOS problem isn’t Qubes specific since Kali works without problems.
Does someone else has this issue too?
If you wan’t boot qube from USB you need to permanently attach usb to it. It might require attach full controller, not device itself. If you have only one usb controller in your computer (most cases) you will end without usb on the rest of qubes (including keyboard and mouse).
When I attach the USB controller including the USB stick to the VM that should boot from it I can’t select the USB stick in the device settings. (Probably because it isn’t attached to sys-usb anymore) And maybe a year ago booting from a USB stick worked without problems. (It was just necessary to select the USB stick and then the VM used the operating system of that stick)
I got the feeling that this is a bug.
