Boot loop after correct luks key
I did a fresh install of qubes 4.2.4 and had at first multiple problems with my sys-usb.
After solving them I’m now getting stuck in a boot loop.
When I enter a correct luks keyphrase it starts but when the loading bar reaches approximately half it shuts down and I have to enter the keyphrase again. It goes on indefinitely. When it first occurred I just did a fresh install, but it is now the third time that it is happening.
After a fresh install, shutting down and booting multiple times, the error did not occur. Only after multiple hours of inactivity does this happen.
When I can type in my passphrase and press esc, all the startup checked are shown that everything is okay.
The last messages are:
[ok] Finished modprobelconf igfs service - Load Kernel Module configfs…
[ok] Finished modprobelconf igfs.service - Load Kernel Module configfs.
[ok] Finished systemd-udev-trigger service - Coldplug All udev Devices.
After that it just reboots and begins again.
Hi w4rl0rd
Can you try and edit the GRUB boot options like this:
:slight_smile:
Hi Chris,
unfortunately after making some other changes all files related to grub were deleted? or are unavailable. After a restart I had only the option to get to my uefi settings. Now I’m doing a fresh install again, maybe next time it happens again I’ll try these changes. Thanks
Hi w4rl0rd
A trick with the installer:
  1. Load GRUB from the Qubes Install medium, as when you install Qubes OS
  2. When you see the GRUB boot menu, hit c to get to the grub>-prompt
  3. type configfile ( and hit tab – you should see a list of available drives. If you only see one, it’s probably just the install medium … but if you have more than one (say hd0 and hd1), you might be able to load the GRUB menu from the harddrive.
On a test machine, I have (hd1,gpt1)/efi/ so I can load the GRUB menu from the harddrive with:
configfile (hd1,gtp1)/efi/qubes/grub.cfg
:slight_smile:
Hi Chris,
thank you for your tip. After installing everything again I tried this: Kernel-latest 6.13.6 boot loop
The problem seems solved, apparently updating kernel-latest to kernel-latest-6.13.8-1.qubes.1.fc37.x86_64 from kernel-latest-6.13.7-1.qubes.1.fc37.x86_64 helped in solving it.
Thanks, again. Have a nice week
Hi w4rl0rd
Nice that you got it to work!! :slight_smile:
If possible, would you mark your post as the solution – in case others with a similar problem should stumble upon these posts, looking for a solution?
:slight_smile:
