Boot fail .. huawei d14
Hello… I have a problem. I burned the copy to the USB but it does not boot. It shows me boot fail… Device type: Huawei Matebook D14
hi,
how did you put the Qubes OS installer on the USB disk?
I burned the iOS version using rufus-4.5 and followed the instructions on the installation page. After finishing, I turned off the device and went to the boot to run the system, but it shows me that the boot failed.
Did you disable Secure Boot in the BIOS?
yes
Did you write the ISO in Rufus in DD mode?
Did you verify the downloaded ISO that it’s not corrupted?
Did you re-verify the installation media after writing?
