I am new here and try to check if Qubes will fit my needs.
I use an LG Gram, so a common Intel setup.
I’ve already managed to set up my bluetooth mouse in sys-net.
I have a sys-usb cube.
Currently, I assign the bluetooth device via the device manager from sys-usb to sys-net in the control panel.
For testing purposes, my /etc/qubes-rpc/policy/qubes.InputMouse contains:
sys-net dom0 allow
sys-usb dom0 allow
This works, but I have the following issue:
As long as I move the mouse (right after connect), everything is fine. But when I pause mouse movement just a couple of seconds, the mouse stops working. So the cursor does not move anymore. When the mouse is reconnected or even the visibility of the bluetooth adapter is changed (via sys-net settings) the mouse is working again until I pause mouse movement again.
Does anyone have a clue?
Best regards
Alex
