The installation scripts and provided tools may have bugs, be vulnerable to Man in the Middle (MitM) attacks or other vulnerabilities.
Adding additional repositories or tools for installing software extends your trust to those tool providers.
Please keep in mind that using such a VM or VMs based on the template for security and privacy critical tasks is not recommended.
How to Create a BlackArch VM
BlackArch Linux is an Arch Linux-based distribution for penetration testers and security researchers. The repository contains 1434 tools.
- List of tools
- Installation Instructions
Create ArchLinux Based BlackArch Template
Create ArchlLinux Template
- Follow the Archlinux Template instructions
Update Template
sudo pacman -Syyu -
Clone template
Via Qubes VM Manager
Via command line
qvm-clone archlinux blackarch
Install BlackArch repository
$ curl -O https://blackarch.org/strap.sh # The SHA1 sum should match: 34b1a3698a4c971807fb1fe41463b9d25e1a4a09 $ sha1sum strap.sh # Set execute bit $ chmod +x strap.sh # Run strap.sh $ sudo ./strap.sh -
Install tools
install all tools
sudo pacman -S blackarch -
or by category:
# list available categories pacman -Sg | grep blackarch # install category sudo pacman -S blackarch-<category> # example sudo pacman -S blackarch-forensic -
or specific tool
# Search for tool pacman -Ss <tool-name> # Install tool sudo pacman -S <tool-name> # Example pacman -Ss burpsuite sudo pacman -S burpsuite
Create a AppVMs based on the
blackarchtemplate- (Optional) Attach necessary devices
Alternative Options to BlackArch
- Page archive
- First commit: 08 Dec 2020. Last commit: 08 Dec 2020.
- Applicable Qubes OS releases based on commit dates and supported releases: 4.0
- Original author(s) (GitHub usernames):
- Original author(s) (forum usernames):
- Document license: CC BY 4.0
