Hello,
following the documentation:
It is possible to mount FILES only
While trying to mount a directory with sub-directories and files, it fails
The mounted directory is not mounted correctly, so no sub-directories nor files are available.
How could a directory be mounted with dub-directories and files available ?
My Scenario:
I am trying to mount a crypttab file and a folder containing the necessary LUKS KEYS
ls /rw/bind-dirs/etc/crypt*
/rw/bind-dirs/etc/crypttab
/rw/bind-dirs/etc/cryptkeys/luks-<UUID_01>.key
/rw/bind-dirs/etc/cryptkeys/luks-<UUID_02>.key
/rw/bind-dirs/etc/cryptkeys/luks-<UUID_03>.key
with configuration in /rw/config/qubes-bind-dirs.d/50_user.conf
binds+=( '/etc/crypttab' )
binds+=( '/etc/cryptkeys/luks-<UUID_01>.key' )
binds+=( '/etc/cryptkeys/luks-<UUID_02>.key' )
binds+=( '/etc/cryptkeys/luks-<UUID_03>.key' )
it would be expected that instead of listing each file, an entry for the directory should have been sufficient, such as:
binds+=( β/etc/cryptkeys/β )
Thanks
