my virtual pi-hole and pi-hole-clone machine is based on a tutorial, installing pi-hole with nextdns.
on sys-vpn i have protonvpn
when I pass a dns leak test on my chokolatvm machine, I have a dns leak, I am trying to solve this problem, since I do not have much knowledge in the field, I hope to have a solution or another proposal so that my chocolatvm machine goes through vpn and pihole, without creating a pi-hole-clone machine
yes if I change position either, my chocolatvm does not go through the vpn, or it is not filtered by pihole, so as it was proposed to me, I had to clone pihole and place before firewall
What’s the purpose of the pi-hole’s here? If you’re trying to use a firewall before a VPN, why not this setup:
vm > dns-firewall > vpn > sys-net
Also, does your vpn have a killswitch? It’s possible to have DNS and IP leaks if the VPN doesn’t have a killswitch that prevents all outbound connections except to the VPN.
and where should I put my pihole machine?
if I do vm > dns-firewall > vpn > sys-net my virtual machine will go through the vpn, but the advertisements will not be blocked by pihole
dns-firewall would replace the piholes in this scenario and block ad domains before the requests are sent out through the VPN qube via a DNS blocklist. Maybe I’m misunderstanding, what applications are you trying to block ads from?
could you tell me how to replace pihole with dns firewall??
I have my chocolate virtual machine, I want that when I connect to my chocolatvm, the advertisements will be blocked, that’s why I installed pihole, and it works but to have a configuration so that pihole works and vpn also works, and for that both work, I created a pihole clone, which I had to place in this configuration
