Better way to restart tool bar when it crash
I see some post talking about tool bar crashing/Disappear.
I regularly have this problem and i just type xfce4-panel in Dom0 Terminal and it goes back.
BUT went i do that all my icon not came back.(For example: I have a icone for my vpn VM -the cumputer with a padlock-). This is annoying because i can’t restart my vpn and other stuff.
Do you now a solution that make my icon goes back when i restart xfce4-panel ?
I don’t now if i am clear…
Thanks for your help !
PS: Or if you now a solution that make my toolbar not crashing at all i will take it too !
Try xfce4-panel --restart
It will restart the current instance instead of starting a new one.
To fix it entirely you could try exploring some other ways. I provided a solution here: [4.1] Xfce menu vanished - #5 by BEBF738VD
Another solution here: Panel disappeared - #6 by monocle
I will look at that !
Thanks
Whatever solution to bring back the panel would be, most probably notification area will miss network related icons.
Bring them back with, for example…
[user@dom0 ~]$ qvm-run sys-net “pkill nm-applet; nm-aplet”
user@dom0 ~]$ qvm-run sys-whonix “pkill sdwdate-gui; sdwdate-gui”
