Emily
1
I seem to have throughly screwed up my system deleting logs manually.
Is there a Terminal command or script that will clear logs without messing up the permissions and folder structure?
And is there a way to get the /var/log folder state back without reinstalling?
unman
2
There was a recent post on exactly this, with a solution. Search the
forum.
ewokky
3
Hi Emily i found this new github page a few days ago that has a log cleaner script for Qubes
#!/bin/bash
sudo journalctl --rotate
sudo journalctl --vacuum-time=1s
#journalctl --rotate
#journalctl --vacuum-time=1s
rm -frv /var/log/qubes/*
sudo rm -frv /var/log/xen/console/*
sudo rm -frv /var/log/libvirt/libxl/
sudo rm -frv /var/lib/logrotate/logrotate.status
#Reboot system after running script mostly due to removing the libxl folder
Please post back any additional tips if you learn anything new
