Best Position to Install NordVPN or other VPN
In your opinion, thinking about privacy, where NordVPN or other VPN application should be installed?
TemplateVM debian-11?
debian-11-dvm?
sys-firewall?
sys-net?
or in the AppVMs?
The idea is to make all traffic that uses USB Wifi Dongle pass throw VPN.
In case of two USB Wifi Dongle, the #1 should use NordVPN and #2 should use, for example, protonvpn.
Qubes provides security through compartmentalization. Following this principle, you achieve the highest security by separating everything.
Therefore, a dedicated VPN qube is preferable:
Contents/docs/configuration/vpn.md at master · Qubes-Community/Contents · GitHub
Upd: New link:
Did you even bother to read the official documentation?
  1. go to Documentation | Qubes OS
  2. Ctrl+f for “How to set up a ProxyVM as a VPN Gateway”
  3. implement it
  4. next time search the official documentation
  5. stop using commercial vpns and create your own
Yes, I have read Documentation.
Please, learn how to read and interpret texts and after that read my post again to note that I’m raising a discussion and asking opinions.
PS: The post is in General Discussion sector, not in User Support.
That’s a interest point of view.
Maybe for a private investigator use qubes for different profiles and VPN installed in a TemplateVM should be an usage way.
