Best idiot-proof-guide for VPNs that will work on 4.3?
so I have been using Qubes for many years now, but find that I am quite dependent on the community for a few things, though I am able to resolve a ton more than i could 8 years ago. Regardless, getting sys-vpns to work has been a bane of my Qubes using existence since the beginning. Between trying to figure out which one i should use, to actually following the guides (many seem sufficiently detailed), to posting and trying to get help on what I am doing wrong - its been a real pain. I am not in much of a position to make demands but it just seems like it could be incorporated into the setup process or a script that could be included in dom0 like create-vpn -ovpn open_vpn_file.opvm -u vpn service user name -p vpn password… I’m going to go out on a limb and assume its not that easy as no one has done it yet (I certainly have no clue how to do it).
I assumed after this upgrade (from 4.2 → 4.3) I should probably use this guide but haven’t gotten that to work and was thinking i’d try this one since i use proton but no, couldn’t get either to work. Other vpn-for-Qubes-for-dummies recommendations are welcome.
Follow only parts of this guide from @solene: Wireguard VPN setup (4.2 and 4.3)
By parts I mean: everything except Set the firewall to the VPN endpoint (this avoids leaks) until Some websites aren’t working. You will have a working VPN that might leak. Wireguard is supported by NetworkManager and provides a graphical interface so it’s your best choice.
If you want to help build such a guide, provide detailed feedback.
Ignore any guide using minimal templates.
If you worry about leaks and errors with config files, firewall etc, just install a GUI version, for example the Mullvad Gui in your template (or dedicated template). Create a dmv based on that tenplate, for example sys-vpn-dvm.
In sys-vpn-dvm, do: (So your vpn account stays saved)
sudo mkdir -p /rw/config/qubes-bind-dirs.d
echo "binds+=( '/etc/mullvad-vpn' )" | sudo tee /rw/config/qubes-bind-dirs.d/50_user.conf
echo "binds+=( '/var/lib/mullvad-daemon' )" | sudo tee -a /rw/config/qubes-bind-dirs.d/50_user.conf
Enable firewall, lockdown mode, vpn connection type etc by opening the Gui in sys-vpn-dvm
And now all you need to do is to create a Named Disposable, sys-vpn, and enable providing network. This setup gives you the option to enable firewall, kill switch etc, in sys-vpn-dvm. So you are sure everything is configured well by the GUI itself without risking leaks.
Thank you @parulin and @tommy , i will try that.
Parulin’s minimal templates quote could be part of my problem (though I’ve gotten it to work in the past) in that if the guide allows, i usually try to use a minimal template.
Last time I tried this, it was not that simple: Mullvad VPN App 4.3 (and 4.2) setup guide
Yes, that’s why i recommend to use the Mullvad GUI solution, especially for people who are not so technically. And you have oversight, every time sys-vpn starts, you can set that the tray icon starts and manage and check your connections easily.
Same thing for the last guide I linked, I’m referring to the Fix DNS section.
My guide is the most idiot-proof, just follow the steps
https://forum.qubes-os.org/t/how-to-make-an-openvpn-gateway-in-qubes-4-2-4-3/
Assuming Debian, not Kicksecure:
I would love it if MirageVPN worked well for this with ovpn config files. It would be perrrrrfect!:blush:
