I would like to know the best desktops for running Qubes 4.1. That is something stable and does not require days of fiddling to get working right. I want a machine that I can install at least 24 gb of ram.
I have a Librem Mini. It was very stable with 4.0 but with 4.1 I immediately started having problems with waking up from suspend and freezing when updating dom0. Because of the issues with the mini, I took the Dell Optiplex 990 out of the closet. So far, it hasn’t given me too much problems except the display would blank out for a second on occasion (perhaps something to do with the video card) and immediately takes me to the login screen. Also 16gb is the max ram.
I have a librem 15 laptop. It has worked well so far with 4.1. The only thing is that there is normally no wifi waking up from suspend and I have to restart sys-net.
I’m using the i9-12900K with 64 GB memory, and for graphics I use an old nvidia 1060
Probably overkill for me. Even my 10 year old 990 runs Qubes fairly well. I’m willing to settle for an older machine as long as it runs 4.1 reliably, has at least 24gb of ram, and can run QHD or better resolution.
