I’ve never tried it on 4.0 (and you have probably switched away from it at this point), but I wrote a shitty bash function that needs id+name combination used in modern qubes as input (instead of just id) for this purpose:
usb-attach(){ # Attach multiple devices to a domain by name
# Use it like this:
# usb-attach <domain> <list_of_usb_device_names>
if [ -z "$1" ]; then
echo "Error: No target domain"
return 1
elif [ -z "$2" ]; then
echo "Error: No devices to attach"
return 1
fi
read -ra devices_target <<< "$2"
readarray -t devices_all <<< $(qvm-device usb list | cat)
echo "Attaching devices:"
for device in "${devices_all[@]}"; do
read -ra device_entry <<< "${device[@]}"
for device_name in "${devices_target[@]}"; do
if [ ${device_entry[1]} = $device_name ]; then
qvm-device usb attach "$1" ${device_entry[0]}
echo ${device_entry[0]}
fi
done
done
unset \
devices_target \
devices_all \
device \
device_name \
device_entry
I think it begs for improvement, especially the input parsing “solution”, so contributions are welcome.
How it works:
Checks if inputs are present with this:
return 1
return 1
fi
Splits the second input into array devices_target (spaces are delimiters):
Splits whatever qvm-device usb list | cat spits out into array of strings devices_all (newlines are delimiters):
Pipe to cat is used to get rid of headings in the qvm-device’s output
Checks each present devices’ name (device_entry[1]) against all given target names (device_name); if true, attaches the device:
fi
done
done
Cleans up after itself because I don’t really know how to apply local
