Hi!
I’m sure this has been asked previously, but I can’t find it when I’ve searched.
I’m having problems copying and pasting to the terminal since this is usually done with ctrl+shift+c/v and these are used for copying from and to the qubes clipboard.
I’m wondering what the usual way that people deal with this problem is, how do you rebind the way you copy/paste to bash and what do you rebind it to?
Thanks.
