I received below error while running apt update using apt-cache-ng. I also used saltstack to run this command. The most suspicious thing is that the error disappeared without me doing anything. Any ideas what happened here? or how can I go about analyzing this?
2024-11-02 21:15:53,173 output: ID: base-packages-refresh
2024-11-02 21:15:53,173 output: Function: pkg.uptodate
2024-11-02 21:15:53,173 output: Result: False
2024-11-02 21:15:53,173 output: Comment: W: An error occurred during the signature verification. The repository is not updated and the previous index fil
es will be used. GPG error: http://HTTPS///deb.debian.org/debian-security bookworm-security InRelease: The following signatures were invalid: BADSIG 54404762B
BB6E853 Debian Security Archive Automatic Signing Key (11/bullseye) <ftpmaster@debian.org>
2024-11-02 21:15:53,173 output: E: Failed to fetch http://HTTPS///deb.debian.org/debian-security/dists/bookworm-security/InRelease The followin
g signatures were invalid: BADSIG 54404762BBB6E853 Debian Security Archive Automatic Signing Key (11/bullseye) <ftpmaster@debian.org>
2024-11-02 21:15:53,173 output: E: Some index files failed to download. They have been ignored, or old ones used instead.
2024-11-02 21:15:53,173 output: Started: 21:14:43.103642
2024-11-02 21:15:53,173 output: Duration: 2437.602 ms
2024-11-02 21:15:53,173 output: Changes:
2024-11-02 21:15:53,173 output: ----------
2024-11-02 21:15:53,173 output: ID: base-packages-installed
2024-11-02 21:15:53,173 output: Function: pkg.installed
2024-11-02 21:15:53,173 output: Comment: An error was encountered while installing package(s): W: An error occurred during the signature verification. Th
e repository is not updated and the previous index files will be used. GPG error: http://HTTPS///deb.debian.org/debian-security bookworm-security InRelease: T
he following signatures were invalid: BADSIG 54404762BBB6E853 Debian Security Archive Automatic Signing Key (11/bullseye) <ftpmaster@debian.org>
2024-11-02 21:15:53,174 output: Started: 21:14:45.604012
2024-11-02 21:15:53,174 output: Duration: 1565.855 ms
