I’ve backups my qubes (AppVMs and Templates VMs) from my machine running 4.2 and I’ve restored them on the machine, after having installed 4.3. As the migration article on the docs says.
The restored went well as the UI gaven me “Success”.
I tried to boot restored Standalone VMs, no issues.
After this, I tried to boot my templateVMs. And they kernel panic.
Below is the full log.
/var/log/xen/console/guest-debian13-minimal.log
[2025-12-18 16:27:37] [ 0.714624] Run /init as init process
[2025-12-18 16:27:37] Qubes initramfs script here:
[2025-12-18 16:27:37] [ 0.719735] Invalid max_queues (4), will use default max: 1.
[2025-12-18 16:27:37] [ 0.725005] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-12-18 16:27:37] [ 0.727566] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-12-18 16:27:37] [ 0.729467] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-12-18 16:27:37] [ 0.733248] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-12-18 16:27:37] Waiting for /dev/xvda* devices...
[2025-12-18 16:27:37] gptfix: Invalid MBR signature: expected 0x55 0xAA, got 0x00 0x00
[2025-12-18 16:27:37] Qubes: Doing R/W setup for TemplateVM...
[2025-12-18 16:27:38] [ 1.117078] xvdc: xvdc1 xvdc3
[2025-12-18 16:27:38] Setting up swapspace version 1, size = 1073737728 bytes
[2025-12-18 16:27:38] UUID=f201f5b8-c1d1-4063-a36a-2564240590a8
[2025-12-18 16:27:38] Qubes: done.
[2025-12-18 16:27:38] mount: mounting /dev/mapper/dmroot on /sysroot failed: Invalid argument
[2025-12-18 16:27:38] Waiting for /dev/xvdd device...
[2025-12-18 16:27:38] [ 1.126710] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem
[2025-12-18 16:27:38] [ 1.128216] EXT4-fs (xvdd): mounted filesystem 307d2357-6997-479d-96ce-e59c9ab99190 ro with ordered data mode. Quota mode: none.
[2025-12-18 16:27:38] mount: mounting none on /sysroot/lib/modules failed: No such file or directory
[2025-12-18 16:27:38] [ 1.139335] EXT4-fs (xvdd): unmounting filesystem 307d2357-6997-479d-96ce-e59c9ab99190.
[2025-12-18 16:27:38] mount: can't read '/proc/mounts': No such file or directory
[2025-12-18 16:27:38] BusyBox v1.36.1 (2024-07-17 00:00:00 UTC) multi-call binary.
[2025-12-18 16:27:38] Usage: switch_root [-c CONSOLE_DEV] NEW_ROOT NEW_INIT [ARGS]
[2025-12-18 16:27:38] Free initramfs and switch to another root fs:
[2025-12-18 16:27:38] chroot to NEW_ROOT, delete all in /, move NEW_ROOT to /,
[2025-12-18 16:27:38] execute NEW_INIT. PID must be 1. NEW_ROOT must be a mountpoint.
[2025-12-18 16:27:38] -c DEV Reopen stdio to DEV after switch
[2025-12-18 16:27:38] [ 1.146093] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[2025-12-18 16:27:38] [ 1.146116] CPU: 0 UID: 0 PID: 1 Comm: switch_root Not tainted 6.12.59-1.qubes.fc41.x86_64 #1
[2025-12-18 16:27:38] [ 1.146141] Call Trace:
[2025-12-18 16:27:38] [ 1.146151] <TASK>
[2025-12-18 16:27:38] [ 1.146160] dump_stack_lvl+0x5d/0x80
[2025-12-18 16:27:38] [ 1.146174] panic+0x157/0x313
[2025-12-18 16:27:38] [ 1.146189] do_exit.cold+0x15/0x15
[2025-12-18 16:27:38] [ 1.146202] do_group_exit+0x30/0x80
[2025-12-18 16:27:38] [ 1.146214] __x64_sys_exit_group+0x18/0x20
[2025-12-18 16:27:38] [ 1.146226] x64_sys_call+0x14b4/0x14c0
[2025-12-18 16:27:38] [ 1.146239] do_syscall_64+0x82/0x160
[2025-12-18 16:27:38] [ 1.146252] ? arch_exit_to_user_mode_prepare.isra.0+0x7d/0x90
[2025-12-18 16:27:38] [ 1.146271] ? syscall_exit_to_user_mode+0x37/0x1d0
[2025-12-18 16:27:38] [ 1.146286] ? do_syscall_64+0x8e/0x160
[2025-12-18 16:27:38] [ 1.146298] ? file_tty_write.isra.0+0x8e/0xa0
[2025-12-18 16:27:38] [ 1.146314] ^C
Following another similar post (without fix), there was the question to check the LV.
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
vm-debian-13-minimal-vpn-private qubes_dom0 Vwi-a-tz-- 2.00g vm-pool vm-debian-13-minimal-vpn-private-1766071658-back 0.00
vm-debian-13-minimal-vpn-private-1766071643-back qubes_dom0 Vwi-a-tz-- 2.00g vm-pool 0.00
vm-debian-13-minimal-vpn-private-1766071658-back qubes_dom0 Vwi-a-tz-- 2.00g vm-pool vm-debian-13-minimal-vpn-private-1766071643-back 0.00
vm-debian-13-minimal-vpn-root qubes_dom0 Vwi-a-tz-- 10.00g vm-pool vm-debian-13-minimal-vpn-root-1766071658-back 0.00
vm-debian-13-minimal-vpn-root-1766071643-back qubes_dom0 Vwi-a-tz-- 10.00g vm-pool 0.00
vm-debian-13-minimal-vpn-root-1766071658-back qubes_dom0 Vwi-a-tz-- 10.00g vm-pool vm-debian-13-minimal-vpn-root-1766071643-back 0.00
As can be seen here, the LV of this TemplateVMs don’t have any data…
How can I solve this ? Is there any logs of the backup restore tool ?
Thanks for the input !
