Auto update template-vms and dom0?
Hey there!
How can i automatically update the template-vms and also dom0?
As dom0 is always running i can maby do it with crontab directly or is there a better solution?
But as the template-vms do not run always, i can not do it with crontab, so what could be the solution there?
Thanks
qun
might be worth checking out:
thanks a lot, will check it out!
