how can I remove the audio model on a qube
Not sure about audio-model, but if you want to stop qube from using audio then you can set its audiovm to none:
qvm-prefs MySilentQubeName audiovm none
just tried that and it still shows i have an audio model
Where are you checking this?
Do you want your qube to not be able to output the sound through your speakers or specifically to not have audio model?
to have no audio model at all Im checking this by qvm-features qube audio-model
You can remove the feature like this:
qvm-features --unset qube audio-model
But it still could have some default audio model if this feature is not set. I don’t know the details.
You can try to disable audio-model like this:
qvm-features qube audio-model False
But I don’t know whatever it’ll work, it’s just a guess.
–unset one worked
