I can’t seem to get the fans spinning fast enough. They don’t even come on until about 70C and then only about 10% at 80C where I think it starts thermal throttling. The required kernel modules that I need have been removed for security reasons. I’m about to cut the blue wires to the CPU fans to kick them up to 100% but I know this is a bad idea, so can anyone please help?
Here’s a link to my machine on the HCL for hardware specs:
Not sure if you’ll be able to fix this in Qubes 4.1.2 since it use Fedora 32 in dom0, but maybe you can try: ASUS NoteBook Linux
But it should work in Qubes 4.2 because it use Fedora 37 in dom0.
which works on bare metal (fedora38) but allowing copr repos is not an option for dom0 as far as I can tell, so I’ve been trying to compile from source from here instead:
but make fails when I try to compile because dom0 has no internet:
[wahcha@dom0 asusctl-main]$ make
cargo build --release
info: syncing channel updates for '1.65.0-x86_64-unknown-linux-gnu'
error: could not download file from 'https://static.rust-lang.org/dist/channel-rust-1.65.0.toml.sha256' to '/home/wahcha/.rustup/tmp/7aj05hr7on6fyvbf_file' failed to make network request
make: *** [Makefile:118: build] Error 1
and then transfered over to dom0 and ran the installer:
[wahcha@dom0 asusctl-main]$ sudo make install
which completed successfully, but asusctl failed to launch because glibc was missing:
[wahcha@dom0 ~]$ asusctl
asusctl: /lib64/libc.so.6: version `GLIBC_2.33' not found (required by asusctl)
asusctl: /lib64/libc.so.6: version `GLIBC_2.32' not found (required by asusctl)
asusctl: /lib64/libc.so.6: version `GLIBC_2.34' not found (required by asusctl)
[wahcha@dom0 ~]$
so I installed glibc, but that only gave me version 2.31 and asusctl needs 2.32 or better:
I tried manually installing a more recent version of glibc, but got bogged down in unresolved dependencies.
@disp6252 You mentioned that Qubes 4.2 will ship with Fedora37 in dom0. That would have a more recent version of glibc in its repos. Where can I find an upstream release of Qubes 4.2 to try?
I built it in and appvm based on the Fedora 37 template. The problem is that I need glibc 2.32 on dom0 to run it. The dom0 repos only have 2.31. That’s why I’m trying on a weekly build of 4.2 now.
The weekly build download link kept failing, so I tried again using the stable release of Qubes. This time I installed to a Fedora37 appvm via the copr repo and copied /usr/bin/asusctl to /usr/bin/ on dom0. That didn’t work either. I’m getting the same errors as before:
[wahcha@dom0 ~]$
I know the answer is to install to an appvm and transfer to dom0 but I can’t get that work. Can I control the CPU/GPU fans with Xen instead?
So, I tried on Qubes 4.2 and actually got rog-control-center to launch and control the keyboard backlight but not the fans. Most of the solutions I’ve found rely on the asus_nb_wmi and/or asus-wmi kernel module(s) which have apparently been deliberately omitted for security reasons.
See marmarek’s comment here about PCI hotplug and DMA attacks:
Is there any practical way to add the asus_nb_wmi driver to dom0?
