layout:
'hcl'
type:
'convertible'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
ASUSTeK COMPUTER INC.
model: |
ZenBook UX564EH
bios: |
UX564EH.203
cpu: |
11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
cpu-short: |
FIXME
chipset: |
00.0 Host bridge [0600]: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a14] (rev 01)
chipset-short: |
FIXME
gpu: |
02.0 VGA compatible controller [0300]: Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] [8086:9a49] (rev 01) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
14.3 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20)
memory: |
16062
scsi: |
usb: |
3
versions:
- works:
'yes'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
6.1.12-1
Remarks
What works
- Suspend (requires
mem_sleep_default=deep to be added to kernel boot paramenters)
- To have wifi work after suspend, add
iwlmvm and iwlwifi to /rw/config/suspend-module-blacklist in sys-net
- Wifi
- Ethernet using adapter
- Camera & microphone
- Touchpad
- Touchscreen
- Audio and microphone through headphone jack
- HDMI output
What doesn’t work
- Assigning PCI devices to qubes using
qvm-pci or the gui (Devices tab greyed out)
- Keyboard backlight, most media keys (but the volume & brightness keys work)
Other info
- Keyboard/touchpad use PCI, so a USB qube can be used
- Power consumption with 10-15 qubes active is 15.94W, with a standard deviation of 3.37W. Battery is 96Wh.
- Nvidia GPU is disabled to reduce power consumption. With it on, usage is around 30W
- Battery life averages around 5.5-6 hours, but can go down to 2-3 hours under heavy load or watching videos.
- 3 USB controllers (00_d.0, 00_d.2, and 00_14.0). Note that these can’t be assigned using
qvm-pci.
- Dedicated GPU: Nvidia GTX 1650
Sven
2
Thank you @SGsQeS4SHNrm for your HCL report, which is online now!
