layout:
'hcl'
type:
'desktop'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
ASUS
model: |
System Product Name
bios: |
1601
cpu: |
11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:4c43] (rev 01)
chipset-short: |
FIXME
gpu: |
Intel Corporation RocketLake-S GT1 [UHD Graphics 750] [8086:4c8a] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Tiger Lake PCH CNVi WiFi (rev 11)
Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 04)
memory: |
31540
scsi: |
Samsung SSD 840 Rev: 6B0Q
Samsung SSD 850 Rev: 4B6Q
BW-16D1HT Rev: 1.01
USB SD Reader Rev: 1.00
USB CF Reader Rev: 1.01
USB xD/SM Reader Rev: 1.02
USB MS Reader Rev: 1.03
usb: |
1
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.52-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
Need to turn on IOMMU in UFEI. No other problems.
Video works after suspend, unlike my older board+cpu. That was huge to save wear on the hardware.
Wifi/Ethernet works without issues.
Some devices show as ie, ‘00:1f.5 Unknown: Intel Corporation Tiger Lake-H SPI Controller’, but they all seem to work.
Although, this step and subsequent procedure to copy qubes to BOOT might have been needed. It was an auto reflex step for me to do, so I never bothered to check.
cp -r /mnt/systemimage/boot/efi/EFI/qubes /mnt/systemimage/boot/efi/EFI/BOOT
Edit: I guess you don’t need to perform the above steps ever since Qubes started using grub. So it seems all that was needed was to turn on IOMUU in the UEFI menu (mobo is UEFI only, does not support BIOS) and the install and everything works correctly.
